2DOF seat mover + ardunio r3+IBT2
Discussion in 'DIY Motion Simulator Projects' started by yeclimb2, Jun 3, 2018.
  1. yeclimb2
    yeclimb2 New Member
    china chengdu
    68Coins
    Hi all
    First of all,thanks everyone here.
    Materials of my simple project:
    1.channel steel 50x50 which is suitable for fixing motor ,some 50x50 angle steel and steel corners
  2. yeclimb2
    yeclimb2 New Member
    china chengdu
    68Coins
    2.150w dc motor---25:1
    CTC 40mm
      161.9 KB
      584
      106.4 KB
      637
      126.6 KB
      642
  3. yeclimb2
    yeclimb2 New Member
    china chengdu
    68Coins
    3.universal joint from tesla half shaft:rolleyes:
    4.ONE 500W LED power supply
      124.7 KB
      538
  4. yeclimb2
    yeclimb2 New Member
    china chengdu
    68Coins
    5.10k potentiometer x2,
    IBT2 x2
    ardunio r3
      123 KB
      582
  5. yeclimb2
    yeclimb2 New Member
    china chengdu
    68Coins
    6.I use smc3,and follow the thread below,but i made a mistake that i set the clip to255 and max limits to 255(max limits =0 is right) because i misunderstand the step6,so i don't get any movement at fisrt.:mad:
    Initial Setup
    I strongly recommend you follow the steps below if this is the first time you are using SMC3 with your simulator to reduce the risk of damaging anything.
    8. Set Kp to about 400
  6. yeclimb2
    yeclimb2 New Member
    china chengdu
    68Coins
    finished product:cheers
      101.8 KB
      653
      93.4 KB
      605
  7. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Great work would love to see a video of it in action :thumbs:cheers
  8. yeclimb2
    yeclimb2 New Member
    china chengdu
    68Coins
    I will upload a video later.and one more question:
    How to change the degree of motor? in smc3 code or some where to set ?
  9. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Do you mean for a starting point of the seat or to increase the amount of movement you have ?
  10. yeclimb2
    yeclimb2 New Member
    china chengdu
    68Coins
    decrease the amount of movement i have,it's too much now,that is not real i think.
    thank you very much
  11. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Hi can you post pictures of your setting in simtools, axis assignments and tuning centre please ?
  12. yeclimb2
    yeclimb2 New Member
    china chengdu
    68Coins
    is that ok?
    I just want to decrese the amount of movement while don't decrease the power of motor
  13. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Hi if you want to keep the speed then dont touch the tuning centre if you want to reduce the amount of movement the lower the % of which ever dof is moving to much but to be fair yours look low anyway.
    153,764Coins
    +11,149 / 57 / -2
  15. yeclimb2
    yeclimb2 New Member
    china chengdu
    68Coins
    Upgrade:
    The backlash is annoying,so i add two damping(use in motocycle) .Now the response is much more tight and comfortable.
    And now it also can support me with power off:grin
  16. noorbeast
    153,764Coins
    +11,149 / 57 / -2
    What are the specs or link to the dampeners you are using?
  17. yeclimb2
    yeclimb2 New Member
    china chengdu
    68Coins
