  1. Claudemir
    33Coins
    @Pit @RufusDufus @noorbeast @SilentChill
    Hello friends !
    I need an urgent help :(
    I'm having problems with the SMC3 program and with the simtools.
    When I open the program with the power source turned off everything works, but as soon as I turn the power on within 30 seconds the program stops responding.
    I have refit all the wiring, deactivated the antiviros, and the windows defend and nothing solved.
    I'm using an adu3 uno r3 with the ibt2 7960
    The same problem occurs with the simtools.
    please help me solve this problem!
  2. evolaco
    evolaco Member
    Spain
    694Coins
    strange problem, can not use another pc?
  3. Claudemir
    33Coins
    I've already connected to another pc and the same problem occurs!
    I open the SMC3 and everything works correctly even with the power supply on.
    But when I click on square, so I can check the progress of the motors, they work correctly for just a few seconds and the TX of the arduino board that stays on blinks and then the SMC3 hangs :(
  4. Claudemir
    33Coins
    I thought the problem was with my H bridge drivers.
    But as the motors are responding as they should, I believe it's not a spinning problem!
    The motors move in all directions correctly until the arduino flashes the TX led.
    So at this point, smc3 crashes and stops working. and this is happening with the simtools as well
  5. sam poole
    sam poole Active Member
    midlands
    66Coins
    I don't know if it makes a difference but I notice you have a different version of arduino smc3 to Windows utility
  6. Claudemir
    33Coins
    I'm using these versions
  7. sam poole
    midlands
    66Coins
    Really doubtful but have you tried opening the 0.63 utility?
  8. Claudemir
    33Coins
    [QUOTE = "sam poole, post: 157055, membro: 27964"] Realmente duvidoso, mas você já tentou abrir o utilitário 0.63? [/ QUOTE]
    I do not know what could be happening!
    After several tests, I decided to change the socket and the program stabilized.
    My PC and my SimTools were connected to the same outlet and for this reason it did not work!
    Anyone have any idea why this happens?
  9. evolaco
    evolaco Member
    Spain
    694Coins
    Does not have any sense that fails to be in the same socket, now works well?
  10. Arazok
    Arazok Member
    Computer scientist
    783Coins
    What happens, if you do not start SMC3 util but the arduino program and its console and send a command to move the motors in this environment ?
  11. Claudemir
    33Coins
    the error occurs in both smc3 and simtools.
    The strange thing is that I took the power outlet, in which the pc and the motion were connected and everything went back to normal!
    I can not understand why it stops working if the simulator source is connected with the pc on the same network!
  12. bruce stephen
    general contractor
    michigan
    9,115Coins
    grounding issue?
  13. boards77
    boards77 New Member
    china
    107Coins
    Great work! Thanks for sharing
  14. Progect555
    Progect555 New Member
    Россия
    233Coins
    Вем Доброго дня) Подскажите плиз - вот в CMS3 всё работает двигатели повторяют кривые заданные синусоиду, сейчас с этим скетчем можно работать в SimTools и с тем же подключением по пинам в ардуино и мотошелд у меня схема собрана по MODE1 или нужен другой скетч и зеркальное подключение мотошелда и ардуино то есть 5 к 5 4 к 4 контакту и т.д.?!
    152,045Coins
    +11,063 / 56 / -2
    Google Translate:
    New Good Day's Day) Prompt pliz - here in CMS3 everything works the engines repeat the curves given by the sinusoid, now with this sketch you can work in SimTools and with the same connection on pins in arduino and motoshedd. I have a scheme assembled by MODE1 or need another sketch and mirror connection motoslode and arduino that is 5 to 5 4 to 4 contact, etc.?!
    That said I am not sure I understand your issue. I am correct in assuming that everything works OK in SMC3 but you have an issue connecting to SimTools.
    If so can you please post picture of all of your settings.
  16. Progect555
    Россия
    233Coins
    [QUOTE = "noorbeast, post: 158054, участник: 10786"] Google Translate:
    Новый день Доброго Дня) Подскажите плиз - здесь, в CMS3, все работает, двигатели повторяют кривые, заданные синусоидой, теперь с помощью этого эскиза вы можете работать в SimTools и с тем же соединением на штифтах в arduino и motoshedd. У меня есть схема, собранная MODE1, или вам нужен еще один мостольд с эскизом и зеркальным соединением и ардуино, который имеет 5-5-4-4 контактов и т. Д.?!
    Имейте в виду, что вы можете писать на двух языках, но это часть правил форума, в которую вы также включаете английский, делая это через Google Translate в порядке: https://www.xsimulator.net/community/threads/forum-rules.9527 /
    Тем не менее я не уверен, что понимаю вашу проблему. Я прав, полагая, что все работает нормально в SMC3, но у вас есть проблема с подключением к SimTools.
    Если да, можете ли вы разместить фотографии всех ваших настроек. [/ QU
    Sorry, I just do not know well English (((And a newcomer to the forums you can say the first time in my life))))In the program SMC3, everything works and now there is a question - to work with SIMTools you need already another code is arduino or it is possible with the same code (sketch) to work in SIMTools - the picture I attach tomorrow to the message of SIMTools settings correctly they are there or not)
    152,045Coins
    +11,063 / 56 / -2
    If SMC3 works correctly then you just have to configure SimTools correctly, the SimTools Interface settings are included in the SMC3 instructions under the heading Simtools Setup.
    Once The Interface is set up you create a Default motion profile in Axis settings. The DIR box being checked orange or not determines which way each axis/force moves, this is what SimTools expects and you can check it in Output Testing: https://www.xsimulator.net/community/faq/which-way-to-set-simtool-axis-movements.230/
    These are the steps to creating and refining a motion profile: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  18. Progect555
    Россия
    233Coins
    Добрый день) С SimTools разобрался в настройках но есть один вопрос - когда захожу в раздел Output Testing и нажимаю Turn On то двигатели из центрального положения разбегаются в разные стороны и замирают но на изменения ползунков реагируют и поворачиваются - вопрос в том почему так, так как в SMC3 когда программу запускаю двигатели в нулевом положении, прикрепляю изображения настроек!
      152.6 KB
      681
      150.7 KB
      753
  19. jose bravo
    jose bravo New Member Gold Contributor
    ecuador
    - 108Coins
    Hi to all. I thought that the configuration was going to be easy, for that reason I paid for the simtools program; but I have read several tutorials, in the whole, looking for an answer to why the motors of the simulator can not start. All the wiring and programming of the arduino card UNO together with the sabertooth 2x32a are configured as indicated by the forums, but no, I can not make the simulator work. I really feel like I've wasted time and money trying to build a 2dof simulator.
    The simtools program detects the arduino card, also the program smc3 moves the motors, but at the moment of starting the game (lfs, rfactor2, ams, assetto, all patched), there is no movement. Maybe it's some Pid configuration, but that's precisely the problem.
    I have tried several arduino cards, thinking that maybe it could be defective, but the problem persists.
    I have read that some people have had the same problem, but I have not found the solution.
    I have tried everything, changing the configuration of the language in windows 7, and I can not solve it.
    Maybe the administrator is already tired of reading that many people can not make their simulator work. I hope he has the patience to explain the reason for my problem.
    Thank you very much.
    152,045Coins
    +11,063 / 56 / -2
    Is SMC3 configured correctly and respond as expected?
    If yes then please post all your SimTools settings. If not the go back over the SMC3 instructions at the start of this thread.
