2DOF w/traction loss(scn6)
Discussion in 'DIY Motion Simulator Projects' started by ShawnStashek, Feb 6, 2018.
  1. joe extraknow
    joe extraknow Member Gold Contributor
    1,550Coins
    Great. Try rFactor 2 and hit all the apex. rFactor suspension deflection is very accurate vs real ones:
    I believe that tire deflection and rideHeights movements are very accurate too. The resolution of SCN6 could be high enough to test for this comparison. the spectra is up to 120 Hz for Sim-X SW and 100 Hz for SimTool feed, but I dont expect the SCN6 can produce that high, but shall produce lower modes.
    Here is the SCN5 with SimX SW on project car:
    Here is the SCN6 with SimTool:
  2. ShawnStashek
    ShawnStashek Member
    Stevens Point, WI
    338Coins
    Just a small update. Rear hoop has been added to the chassis which will be used for the harness tension system. received_10211624299862415.jpeg
  3. joe extraknow
    1,550Coins
  4. ShawnStashek
    ShawnStashek Member
    Stevens Point, WI
    338Coins
    Harness tension system about half way done. Then it's just finding the balance point of the chassis for u- joint placement and the actuator mounts. Finally getting close to being able to test this thing out.
  5. DoryDriver
    DoryDriver New Member
    Canada
    258Coins
    Looks great. You're build is similar to what I am planning on making. I was going to recreate a setup like this but with pgsaw motors.
  6. Schopfer
    Schopfer Member
    Thailand
    86Coins
    Nice cockpit
  7. ShawnStashek
    ShawnStashek Member
    Stevens Point, WI
    338Coins
    Chassis is wrapped up, other than a couple of odds and ends. Balance point has been found. Finally starting to see the finish line.
  8. ShawnStashek
    ShawnStashek Member
    Stevens Point, WI
    338Coins
    In anticipation of fabrication getting wrapped up, I decided to take care of mounting all of the various electrical components under the platform. Getting anxious to actually start testing this thing out.
  9. ShawnStashek
    ShawnStashek Member
    Stevens Point, WI
    338Coins
    Brought the traction loss frame home despite it still needing a couple things done. Mocked it up to figure out the path of the transfer balls through their full range of movement. Need to get the plates cut for them to ride on which are made from 1/8" stainless. Trying to take care of the small things like this so once everything is ready to be assembled I don't have things slowing me down.
    20180827_134443.jpg 20180827_134814.jpg 20180828_133332.jpg 15354867999361242847677.jpg
  10. ShawnStashek
    ShawnStashek Member
    Stevens Point, WI
    338Coins
    Working on getting the u joint mounted. Then its just mounting the actuators and a few odds and ends. Decided since it's been over a half year since I've done any sim racing, I should connect everything to the pc and fire it up and make sure everything is working. I was still using mmos, switched over to Simucube. Also upgraded to a biss encoder and got that configured. Just have a loose wire in the fanatec adapter to take care of so the wheel works. Everything else is functional, pedals are still on the rig at the shop, but don't anticipate any issue with them. Rig construction should be completed by next weekend.
  11. Talkwrench
    Talkwrench Talkwrench
    Maintenance Supervisor
    United Kingdom
    172Coins
    Wow. Sick build, loving the execution :thumbs
  12. ShawnStashek
    ShawnStashek Member
    Stevens Point, WI
    338Coins
    Thanks. Hoping it works as good as it looks.
  13. ShawnStashek
    ShawnStashek Member
    Stevens Point, WI
    338Coins
    Actuator standoff mounts are just about wrapped up. Time to get them mounted on the rig!
  14. ShawnStashek
    ShawnStashek Member
    Stevens Point, WI
    338Coins
    Fabrication complete! Getting the traction loss frame powder coated, hoping to be assembling this weekend. Completed length was a few inches longer than my initial plans. So I had to build a new platform for it. Decided to lower it and heavily reinforce any area where weight will be sitting.
    20180911_150849.jpg 20180911_150900.jpg 20180911_150912.jpg 20180911_131835.jpg 20180911_131926.jpg 20180911_131945.jpg
  15. ShawnStashek
    ShawnStashek Member
    Stevens Point, WI
    338Coins
    Underside view of the platform and the start of cable management.
    20180908_143349.jpg 20180908_143327.jpg 20180908_143337.jpg 20180911_135720.jpg 20180911_135644.jpg
  16. ShawnStashek
    ShawnStashek Member
    Stevens Point, WI
    338Coins
    Spent a little time cleaning up the chassis. It will eventually get powder coated but want to test it for a while to make sure everything holds up and no modifications need to be made. It would look great polished, but I don't think I have the patience to do that. Started assembly today. Pick up the traction loss frame from powder coating in the morning, so I should have it completed tomorrow.
  17. ShawnStashek
    ShawnStashek Member
    Stevens Point, WI
    338Coins
    Fairly productive day so far. Pressed the transfer balls into the traction loss frame. Got the plates aligned and screwed down. Installed u- joint and got the cockpit bolted to the u- joint. Currently waiting for ups to deliver the bolts to mount the actuators.
    20180914_113023.jpg 20180914_114317.jpg 20180914_120342.jpg 20180914_120329.jpg
  18. ShawnStashek
    ShawnStashek Member
    Stevens Point, WI
    338Coins
    Just some loose ends to wrap up at this point. Nice to finally see it more or less complete after 8 months from the start.
  19. yobuddy
    51,355Coins
    Really nice looking sim buddy! :thumbs
  20. Javo5
    Javo5 Active Member
    Buenos Aires, Argentina
    300Coins
    Awesome rig!!!:thumbs:thumbs:thumbs
