New Motion Sim Project Using AMC
Discussion in 'DIY Motion Simulator Projects' started by lamealot, May 10, 2009.
  1. lamealot
    lamealot New Member
    0Coins
  2. RaceRay
    Hamburg, Germany
    23,877Coins
    I found a interesting summary of single-phase motors. Hope it helps:
    http://www.allaboutcircuits.com/vol_2/chpt_13/9.html
    As i read so far from another site (unfortunately in german) is that you can reverse the direction of a single phase motor by interchange the connection of the starting winding which is the winding that connects a start capacitor. The capacitor is needed for starting purposes to get a needed phase difference,i think.
    Is it right, no frequenz inverter is necessary for a single phase capacitor motor? I asked the seller about the connection terminal to find out how many wires the motor got.
    Btw. I really like your projects, specialy the GPS tracker...fine thing :)
  3. lamealot
    lamealot New Member
    0Coins
    i am being slowly lurred into the idea of stepper motors :sos:
    advantage of that being one can raid old washing machines for motors but this is just a wild thought because i have drunk too much coke this evening
  4. wannabeaflyer
    wannabeaflyer Active Member
    UK - London area
    973Coins
  5. lamealot
    lamealot New Member
    0Coins
    they look like hairdryers but @ 120w should be ok so long as they got some torque behind them. £13!!! I might buy one just to turn my front door key! :thbup:
  6. wannabeaflyer
    UK - London area
    973Coins
    yeah know what you mean but at that price i'd rather have em to try and sell on if not up to the Job ... i appreciate speed is not great but i can gear it to increase the spped but may loose out on torque ( no May about it ) mind you the Guy in the You tube clip uses the next size up on his 6dof and not bad looking so eagerly awaiting delivery and at least i'll have a benchmark spped wise to work to ... She's been gather dust while i look for DIY actuators so maybe this might get me back up and running :cheers: mind you i use solidworks CAD at work so may get a chace workload permitting to do some simulation after i create a model for these units ... 51Nm torque at 1 meter so figure on 4 times that over 250mm Actuator arm throw .. would be nice
  7. lamealot
    lamealot New Member
    0Coins
    it would be interesting to see where you get the 6DOF position data from for your project unless youo already mentioned that but i missed it?
    I now seem to have an option for the controller part thanks to discovering this little baby. Based on the Atmel AT Mega166-A it is the superman of motor controllers but although it is already geared for upto 40v motors i am modifying it to output for larger motors. (or maybe both, lets see how it goes)
    Large schematic here, was too large for attachment http://fsuipc.co.uk/img/schematics.jpg
    An added bonus is that i have the original Eagle files which is my preffered prog :thbup:
    So there is a small chance this thread may take a new direction
    Chris
  8. lamealot
    lamealot New Member
    0Coins
  9. lamealot
    lamealot New Member
    0Coins
  10. tronicgr
    tronicgr
    Hi Chris,
    This controller you link to, is not the same thing as my AMC.
    Its a PLC meant to be used with industrial machines. I don't know if you can use such controller for motion simulator, and even if possible, you still need to program it yourself!!!
    Thanos
  11. lamealot
    lamealot New Member
    0Coins
    yes, at the age of 30 I have learned the important stuff must be done myself (programming). A friend is looking at the board now and only has concern for the PWM output voltage so far but in general it is looking good. As for firmware I will just need to modify Ian's PICAXE code to use the correct lines.
    The thing i like most about this board is the support for stepper motor possiblility, well at least for playing :yippiee:
    Chris
  12. lamealot
    lamealot New Member
    0Coins
    ok so the final word on this board http://www.yourdci.com/product.php?productid=1&cat=1&page=1 is that it is suitable for the job but requires an additional 4 mosfets and current sense resistor to run 24vdc motors upto 16amp. That seems pretty simple to me but ofcourse Ian @ BuiltforFun will charge me £50 just to talk to him about his firmware and AMC firmware will be kept compiled forever.
    Anywayz, watch this space because there is soon to be an 'out of the box' system materialize before your very eyes. Soldering iron soldiers need not watch this thread lol :thbup:
  13. RaceRay
    Hamburg, Germany
    23,877Coins
    Hi Chris,
    imho i really suggest you to try out Thanos AMC interface and build up on this as your starting point. There are many advantages than using a interface which is hardly unknown:
    • 1) A lot of Sim projects use it already
      2) You don´t need to program the microcontroller by yourself
      3) You`ll get great support - think that´s the most important part of it
      4) costs are less expensive than as for your mentioned interfaces ( if we don´t quote our working hours)
      5) It´s a challenge to see some working sims with the AMC and (maybe) AC motors
      6) It´s the thought of DIY! Why something purchase, when we can make it by ourself?
    You aren´t but i bet you are the guy with the most posts within a minute :D
    You are promising a lot, we`ll see ... and watch that thread
  14. lamealot
    lamealot New Member
    0Coins
    Something will definitely happen here but hopefully a good thing :clap:
    The lure of stepper motors has got me by the danglies! There was a post here about steppers but it faded into oblivion like most posts do with no cigar at the end. For that reason I suggest continuing that investigation until we are all clear I have wasted my time and money.
    Here are some benefits of stepper motors
    1. High Torque at low RPM
    2. No position feedback required
    3. Lots of driver boards available off the shelf
    4. Can be run directly from PC/serial with no microcontroller required, just send the signal and the motor does what it is told
    So today my ebay fingers were itchy and i bought this little baby!
    3 Axis 8 Amp CNC Driver Board 4 UNIPOLAR Stepper Motor
    and a TTL gizmo based on the CP2102 which is my favourite serial converter chip at the moment.
    Although it is 8 amp, unfortunately only pokes 24vdc but this is ok because the first tests here will be to create a small prototype. The driving software is the important step here, sizing up equipment will be later.
    btw, soon I will delight everyone here with the sight of a motion chassis that can roll upto 90 degrees. And it has been made professionally by a local fabrication company :cheers: Just waiting for a few more welds to be done
    Chris
  15. Mambo
    Mambo New Member
    Czech Republic
    288Coins
    Well stepper motors has 0 tolerance to over power. If you do that they loose steps. It isnt so easy with no position feedback. You need some calibration after every start.
    3) and 4) same as DC servos
    Steppers are good on CNC machines but only for small ones ! If you use more powerfull motors cost is nearly same as servos.
    Thanos board is so far best choise. On ebay are plenty powerfull drivers (+-10V control) for AC motors for great price.
    Edit: for example this can handle really big motors http://cgi.ebay.com/Advanced-Motion-Con ... 7C294%3A50
  16. cauehawaii
    cauehawaii New Member
    3Coins
    hey man..
    I have purchased the motor below (Bosch 24V 9A), and the power supply (Switched Power Supply Stabilized 201W 24V 8A)...not sure if it will work..but I will try..
    the power suply will be here this weekend and I will send some pictures of my first test..I hope I dont burn things :)
    my post is:
    basic-2dof-configuration-and-faq-t1555-10.html
    feel free to drop anything that may be useful
    regards
    Caue
  17. lamealot
    lamealot New Member
    0Coins
    i would have used the AMC board but I required the -10v,+10v circuit to be added as optional connector before going to print. I PM'ed R-eng about this but no reply and there was no interest in the original sprint files for AMC being published so i could do it myself.
    The concerns mentioned about steppers are interesting. No way can I argue them because this is new territory for me and slightly out of my technical league. The main reason for doing this with steppers is that the hardware is very common unlike the deal with DC motors. It is unbelievable that with all the motor control project boards out there that non of them can work with the available motion systems! Surely the practical way to do a motion project is to start with an existing 'off the shelf' board! To create a dc motor driver from scratch around the software seems back to front. The software/firmware should be written around the existing hardware.
    Does anyone agree with that?
    This test will involve a traditional 2DOF base but smaller scale for testing. It will probably be just big enouogh to take my 10 year old kid for a buckaroo ride :thbup: If the FET's fry then at least we have absolute proof of the stepper theory being busted, no tears for trying.
    It will be tested to the max I promise you that. Creating the motion signal app will be great fun because I have just discovered an offset in FSUIPC that allows to calculate the hardness of touchdown :cheers: My landings are perfect so will never see that in force but will no doubt screw up a landing to test it :yes:
    Chris :blush:
  18. Mambo
    Mambo New Member
    Czech Republic
    288Coins
    Well all hardware is already here .. AMC + H-bridge for DC motors.
    AC motors are so far really expensive but can be done (you can use H-bridge with 10V powersupply to control big servo amplifier(driver) :D )
  19. lamealot
    lamealot New Member
    0Coins
    yes but needs to be built and no control over logic because the firmware is not open source. Is x-sim open source?
  20. lamealot
    lamealot New Member
    0Coins
    not too concerned about the stepper response now having read that the board I am using is capable of 1000RPM. Thats alot of step signals!
    In fact, stepper motors are designed for this sort of application. Has anyone ever questioned the reliablility of DC motors for positioning. Continuous stopping/starting of dc motors in various directions puts a terrible strain on them so i bet they are being replaced very often in existing sims.
    Chris
