Tutorial GameVibe Manual
Discussion in 'Tutorials and Tips by the Developer' started by yobuddy, Dec 25, 2017.
  1. abs
    consultant
    Montreal
    764Coins
    3DOF, SCN5
    if you run 2 pc : try open gamevibe first then open gameengine (on second PC) and open the game (in third on the main gaming PC)
    If you run only one PC : try open 1st gamevibe , then open simtools , then open the game
    (remeber all the effects are muted by default in gamevibe/profile editor . you have to unmute them (do open (see loudspeaker logos) one at a time for testing puposes each effect while in a game)
  2. yobuddy
    51,197Coins
    Thx for the feedback guys.
    makes it easier to know what to look for when I go over GameVibe for a proper release.
  3. Gelatin
    Gelatin Active Member
    Hungary
    - 376Coins
    3DOF, SCN5
    Hi Guys!
    I'm using Game Vibe with iRacing recently and I encountered with a problem, simply freeze and got a message which says GameVibe3 or GameVibe4 and waits for me to press OK. While it waits the vibration continue in the frequency when it freeze. After OK, it restarts and works fine until the next freeze. You Guys can see it in the video.
    LFS works fine for me, it just iRacing...
    Do You have any idea how can I(maybe others) overcome this?
  4. yobuddy
    51,197Coins
    @Gelatin
    Please set your PC like this buddy and try again buddy.
    Take care,
  5. Evan Rowlands
    Evan Rowlands EMR Industries
    Melbourne Australia
    - 82Coins
    gday guys i have no gear shift output its blank.. even in the tunning centre its blank any ideas
  6. yobuddy
    51,197Coins
    what game?
    Got a pic maybe?
    Take care,
  7. mariano68
    mariano68 Active Member
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
    I did my first testings with GameVive and LFS... what a fantastic job you did @yobuddy ! :cheers
  8. yobuddy
    51,197Coins
    thx buddy! :cheers
  9. Gelatin
    Hungary
    - 376Coins
    3DOF, SCN5
    Thanks yobuddy!
    That was the problem, but I had to set my PC to full english language to get it work.
    Is it possible to fix this issue, It could be good to use my PC with my language package and of course running game vibe as well.
    take care, thx
  10. yobuddy
    51,197Coins
    "but I had to set my PC to full english language to get it work.
    Is it possible to fix this issue"
    I wish buddy, but it seems to be very hard to replicate.
    I simply have not been able to get it to not work lol.
  11. Claudemir
    23Coins
    Hello friends, what equipment do I need to be using the Vibe game? I'm trying to do the same work you're using. Sorry for my ignorance, but I'm very lazy in programming parts if you guys can help me. I'll be very grateful.
    I have some Logitech 5.1 speakers with which do I do this procedure? Or should I have something like a replacement speaker with a power supply and an amplifier?
  12. ilbiga
    ilbiga Active Member
    Network Engineer
    103Coins
  13. Claudemir
    23Coins
  14. yobuddy
    51,197Coins
  15. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    Well... i try to explain and make easy for you: buy 4 or 8 aura shakers; 4 for tires position, and 4 for seat, back, shifter and pedals. Ok. Buy 2 amplifiers with 2 in stereo and 4 out stereo at 4ohms each. Put aura shakers on correct position and its done !
  16. ilbiga
    Network Engineer
    103Coins
  17. ilbiga
    Network Engineer
    103Coins
  18. paulopsx2
    brasil
    647Coins
    Awesome ! Aura its the same like this. Just verify your transducers in first atempts because low frequencys put shakers too hot if you use an amplifier with more power. ( 50watts x4 ch its more than sufficient )
  19. ilbiga
    Network Engineer
    103Coins
    @paulopsx2 I agree! :thumbs
    The first tests actually show an excessive heating of these transducers. I have yet to fix several things! :grin
  20. riton
    riton Active Member
    1,006Coins
    my BTK LFE heats up a lot.
    20 min and it goes into safe operation.
    it does not work anymore, what do you recommend?
