DIY G-Seat (from concept to final)
Discussion in 'DIY Motion Simulator Projects' started by early_m, Feb 21, 2018.
  1. SeatTime
    Nice work :thumbs, but watch out, chasing realism is a slippery never ending slope :).
  2. early_m
    early_m Active Member
    Chelmsford
    839Coins
    Thanks. I'm hoping this will provide what I've looking for, although I've found myself looking at the D-Box style linear actuators more and more....
  3. early_m
    Chelmsford
    839Coins
    Slow process but the frame is done
    The peddles retract in and out so only takes up 1 metre of room making it fit in a specific spot in my office
    Next step will be to incorporate the wheel braking g force system
    • Like Like x 6
  4. Sebj
    Sebj Active Member
    Canada
    492Coins
    Very innovative side panel design, good stuff.
    I wonder if you beat the gs5 to it!
  5. early_m
    Chelmsford
    839Coins
    Thanks, to be honest I'm surprised that there isn't something similar already, very simple.
  6. yobuddy
    51,535Coins
    Great Work @early_m !
    Really like the pedal pull-out design!
    Have you ridden it yet?
    Maybe add a cheep 3D Game Vibe setup for some extra feedback.
    Take care buddy,
  7. early_m
    Chelmsford
    839Coins
    Thanks very much, I'm hoping to take it for its first test ride tomorrow as its now complete with the final piece of the puzzle in place - the wheel braking g force setup
    I've previously taken a look at the game vibe option and it would be a great addition down the line
  8. hjr2
    hjr2 Member
    Canada
    120Coins
    DC motor, Arduino
    I have to remember that sliding pedal rack. Great way to conserve space!
  9. early_m
    Chelmsford
    839Coins
    Small amount of time today to start tidying up the electronics.
    Starting with a simple cover plate for the power and data sockets
    I originally sliced the ends off some servo cable extension leads to connect everything up, but always thought it was a bit messy. So I put together a little breadboard circuit that allows me to plug my servo connectors straight in, kind of like a servo shield. Made a little housing unit to keep it all tidy and protected
    Lower case
    Uno and breadboard installed
    Full assembly
  10. early_m
    Chelmsford
    839Coins
    Onto the final straight now. Have painted the frame a gloss black and now looks a bit less 'red neck"
  11. early_m
    Chelmsford
    839Coins
    Installed the electrics to the inside of the frame under the seat:
    220v AC to 12v 10A DC PSU
    6V DC/DC Buck converter
    Arduino and breadboard unit
    Power and data in sockets and mount
  12. early_m
    Chelmsford
    839Coins
    Made a little mechanism to handle the cable slack under the pull out pedal section
    Closed
    Open
  13. noorbeast
    153,866Coins
    +11,153 / 57 / -2
    Congrats on the detailed thought and work that has gone into your rig, right down to the really neat switch panel and cable management system.
  14. MAYAman
    MAYAman New Member
    97Coins
    This is a great project. Do you know what the life cycle of the actuators are? Are there more powerful commercial actuators which would do a better job and have a longer life cycle?
  15. early_m
    Chelmsford
    839Coins
    Thanks, it's been fun making it and building on design concepts.
    The servos were cheap - picked them up for about £12 so I'm not expecting much from them. They are currently doing an exception job though. Only time will tell on their life span. Worryingly current stock levels are low so the price has gone up. These are 33kg.cm. There are higher priced, higher torqued servos available like this one https://hobbyking.com/en_us/jx-pdi-...ge-digital-power-servo-62kg-0-13sec-200g.html
    And slower insanely powerful ones (maybe suitable for flight sim) like this one https://www.aliexpress.com/item/SUP...rvo-12V-24V-DC-Input-Support/32835144507.html
  16. MarkusB
    4,215Coins
  17. early_m
    Chelmsford
    839Coins
    are you able to make a video of them in operation?
  18. MarkusB
    4,215Coins
    I already did: See the first video within the first post of my new thread. In this video I perfom the SimTools output test for showing the movement of all motors. You can see the heave flaps and the backrest move between sec. 00:25 and 00:40. Each heave flap is moved by one Super500 servo, and the backrest is moved by two of them.
    Since I move the SimTools sliders quite fast, the video shows the maximum speed of the servos. I have also added some pictures in this post where you can see the mounted servos.
  19. MAYAman
    MAYAman New Member
    97Coins
    Thank you, good information. Do you know if these could be swapped out with the GS4 servos? My GS4 has two dead servos from 3 years of use. I want to replace them with super strong long life servos that will give me more feeling and longer life.
  20. Tags..(VR)
    Tags..(VR) Member
    indiana
    - 6Coins
    was this build on top of having 2 dof?
