SimTools Presets 2DOF Arduino Simulator with rear wipers
Discussion in 'Game Engine Interface presets' started by RacingMat, Nov 6, 2013.
  1. Aman sharma
    Aman sharma New Member
    India
    63Coins
    thank you sir
    i am facing problem in using the software can you please give me any tutorial to how to use the software. i have already tested the coding and it runs fine with a small dc motor,but how should i incorporate the game motion to get the desired output in the motor.
    • Old Old x 1
  2. Aman sharma
    India
    63Coins
    can i start testing game and hardware without plugins
    153,818Coins
    +11,150 / 57 / -2
    The fully functional Live For Speed plugin is bundled with SimTools, specifically for testing purposes, so use that to test your hardware.
    Have a look through the SimTools section of the FAQs: https://www.xsimulator.net/community/faq/simtools-settings-tips-and-tricks.18/category
    In particular follow the setup steps to creating and refining a motion profile: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  4. Aman sharma
    India
    63Coins
    i will go through it. thank you very much sir. :)
  5. polybasss
    polybasss Member Gold Contributor
    Burgos Spain
    155Coins
    Thank you very much, I am having a lot of problems to make my 2dof move correctly, I will try your configuration to see how
  6. polybasss
    Burgos Spain
    155Coins
    It works, finally! Thank you very much for this post, now to see if I do it with a game
  7. polybasss
    Burgos Spain
    155Coins
    The empty tests are good, but when I do this, I do this ... I also do it in games, do you know what it can be? It is as if I could not with weight and weight 77 kg
    Thank you
  8. jeanmehdi
    jeanmehdi New Member
    LONDON
    - 201Coins
    Will give this a try as soon as i can, thanks Man :)
  9. TREX998
    TREX998 New Member
    - 18Coins
    Thanx your
