  1. imagebuff
    imagebuff New Member
    Tomball TX
    269Coins
    Very nice setup!
  2. Daguru
    Kitchen installer
    Wales uk
    468Coins
    Motion platform
    love the black seaflo's:thumbs
  3. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    my black seas !! rs
  4. Nick Moxley
    Having the fans Right up and in YO face wasn't an option for me, and my A/C cooling Ice Cream pail setup while it works, Was is need of a replacement. Enter the Seaflow's and 3" pipes with custom splitter for 2 3" runs and a single 1.5" run. 3" threads onto the Splitter and 1.5" pops on with a little wiggling.
    Black paint job is also probably in order.
    I also have an Offering for the guys who want to run their Fans in Telemetry mode, Or at the flip of a switch and a simple 180-360deg pot, you can control them on the fly.
    This Script was from our Own @tadythefish and he's more than happy to share what he did for me.
    Pot goes on Analog 4 and the Switch on Pin 2. As seen here.
  5. paulopsx2
    brasil
    647Coins
    ok.. interesting.. but WHY just 1 blower?
  6. Markus2018
    Markus2018 New Member
    - 232Coins
    Hi everyone. have a problem with the Monster moto shield have two seaflow In-line blower connected and code uploaded by SillenChill on Arduino Uno.
    My problem is that only one seaflow is running. The one on A2 B2
    A1 B1 does not work
    Tested with Assetto Corsa
    translated with Google
  7. MrJack
    MrJack New Member
    184Coins
    2DOF, SCN5
    May be test the A1,B1 pin, or test the Seaflow ?
  8. mariano68
    mariano68 Active Member
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
    I have a spare MM with the pins soldered on top, anyone knows how to connect with cables and not over the arduino?
    Thanks anyway!
  9. mariano68
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
    Ok...
    Well, just got 40 arduino cables and connected ALL the pins from de MM to the arduino.
    Gamedash id working fine (MATH in range etc), but the MM just shows 2.33v and nothing more than that, tried the original .ino from the first page, the modified one with the diff modes, and also the last one posted with the pot mod, the only one that shows a little response was the last one, that varied from 12v to 13.5, I'm testing with a panaflo server fan.
    Any clues?
  10. Stephen Robotham
    Stephen Robotham Active Member
    jamaica
    130Coins
    Hey guys, thanks for this cool upgrade. It will help while playing in vr, but is there a way to set the math to less than 1 because I have 2 of the seaflo 4" blowers and damn they are loud. Would love if I could turn them down, maybe 50% or 75%, not sure, but definitely too loud and too much wind for me.
  11. paulopsx2
    brasil
    647Coins
    for shure. just put voltage down... its under 12-15v. put at 8-10v and your blower its under 100-120 cfm. see... https://www.youtube.com/edit?o=U&video_id=kWU8dYsSbNY
  12. Stephen Robotham
    jamaica
    130Coins
  13. Stephen Robotham
    jamaica
    130Coins
    Does this work with iracing? I have it working great with assetto corsa but I can't get it to work with iracing, and thats the sim I mainly use. Please help!
  14. Historiker
    9,208Coins
    Yeas it does, I have the wind burns to prove it
  15. Stephen Robotham
    jamaica
    130Coins
    What settings are you using, because it wont work for me?
  16. paulopsx2
    brasil
    647Coins
    try again
  17. paulopsx2
    brasil
    647Coins
    yes it works perfect.
  18. Historiker
    9,208Coins
    Sorry, I am not near my simpit right now. But it would help if you posted your settings instead. Someone could perhaps see whats up and help more.
    When something is not working right, it is always best to post your settings so people can help (PSA for others who might read this). :)
  19. Fernando Romão Filho
    Fernando Romão Filho New Member Gold Contributor
    271Coins
    2DOF, AC motor, Arduino
    [QUOTE = "gorzasty, post: 87445, membro: 6742"] Olá
    Muito boa ideia com o controle do ventilador. Eu vou tentar o mais rápido possível, mas alguém pode me dizer como configurar isso? Eu baixei o código Ardu e o gamedash, mas não sei o que vem a seguir. As imagens na primeira página não aparecem;
    EDIT, ok, agora as fotos estão de volta, talvez alguma hospedagem tenha caído ... mas ainda não sei como chegar ao Editor de Comando [/ QUOTE]
    é so apertar no lapis ao lado do DASH
    152,595Coins
    +11,087 / 56 / -2
    Please be aware that you can dual language post but it is part of the Forum Rules that you also include English, particularly when asking for help, doing so via Google Translate is fine: https://www.xsimulator.net/community/threads/forum-rules.9527/
