DIY Arduino Buttonbox
Discussion in 'DIY peripherals' started by TOPMO3, Mar 28, 2016.
  1. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    well.. this project, its exaclty the same i use on 2012, for physical changes on my f1 add for t500rs. works perfect, but wires between platform and wheel still a great problem... some idea how to wirelless project??
  2. paulopsx2
    brasil
    647Coins
    some pics how to
  3. TOPMO3
    TOPMO3 Active Member
    Russia
    894Coins
  4. paulopsx2
    brasil
    647Coins
  5. Nick Moxley
    17,056Coins
    Easiest Bluetooth setup to do is the BlueHID. its relatively cheap, its dead nuts easy to setup, the only real downside is the size of the board.
  6. TOPMO3
    Russia
    894Coins
    Didn't try yet..
    Input lag is probably higher than wired, but can't say how much
  7. HoiHman
    HoiHman Active Member
    Mechanic
    The Netherlands
    331Coins
    I bought a couple of arduino micro pro's and used the last joystick sketch. Pretty with it and the small size is perfect for building steering wheels.
    Everything works perfect except my CTS rotary encoders. First i had to turn them four steps to register one click, then i switched to " half step" which improved, but it still takes two steps for the rotary to register 1 click.
    So i probably need a "quarter step" setting for my CTS encoders, but i have really no idea how to edit this in the sketch.
    I hope that somebody can help me out here.
  8. Rupe
    Rupe New Member
    Spain
    166Coins
    I have the same problem. Can someone help me?
  9. Nick Moxley
    17,056Coins
    Try Chained for encoders, There is a small bug in the build somewhere on encoders....going to chained fixed it.
  10. Rupe
    Rupe New Member
    Spain
    166Coins
    What do you mean with chained?¿? I'm a newby.
    Thx
  11. Nick Moxley
    17,056Coins
    Options for Encoders are Single or Chained, Set them up in chained the same way you would single. That should solve it for you I would hope.
  12. Rupe
    Rupe New Member
    Spain
    166Coins
    Ok that's perfect but... what do you mean with chained¿?¿¿
    Something like this??
  13. sel
    sel New Member
    uk
    252Coins
    Hi, I'm trying to get started with this and have limited Arduino experience.
    My current issue is the Joystick library, I've placed it in the library folder but that's as far as I get as it doesn't show in the menu or Library Manager.
    There is an error message
    Invalid library found in N:\Program Files (x86)\Arduino\libraries\ArduinoJoystickLibrary-master: N:\Program Files (x86)\Arduino\libraries\ArduinoJoystickLibrary-master
    I also tried using Add zip Library but it still won't show and same error.
    Any Ideas on this one as I'm stumped.
  14. sel
    sel New Member
    uk
    252Coins
    Never mind I sorted the problem, wrong library.
  15. Henrik
    Henrik New Member Gold Contributor
    Sverige
    104Coins
    I messed up the matrix, did not pay attantion to the instruktions "sry"
    Before i cut everything up, is there an way to define button presses by.
    Example: Pin10+pin14=Button12, Pin10+pin21=Button14, in the code?
    Because then i can make it without cutting.
    I got it working with 5 rotaries :)
  16. Henrik
    Sverige
    104Coins
    Never mind, it seams to be to complicated for me, after looking in the keypad library.
    So i resoldered 4 of the buttons and now all of them work.
  17. evolaco
    evolaco Member
    Spain
    698Coins
    Can 6 encoder be used?
  18. JonBakhol
    JonBakhol Active Member
    Netherlands harderwijk
    442Coins
    Hi @Henrik ,
    I was wondering what sketch you are using for the 5 rotaries. This is because I'm busy with an F1 Steering also with 5 encoders and 25 buttons.
    Wheel like attached and using the matrix (also attached)
    I also attached my code, hopefully you can take look at it?
    Many thanks for now,
    Bakhol
    Code:
    //BUTTON BOX
    //USE w ProMicro
    //Tested in WIN10 + Assetto Corsa
    //AMSTUDIO
    //20.8.17
    #include <Keypad.h>
    #include <Joystick.h>
    #define ENABLE_PULLUPS
    #define NUMROTARIES 5
    #define NUMBUTTONS 16
    #define NUMROWS 4
    #define NUMCOLS 4
    byte buttons[NUMROWS][NUMCOLS] = {
      {0,1,2,3},
      {4,5,6,7},
      {8,9,10,11},
      {12,13,14,15},
    struct rotariesdef {
      byte pin1;
      byte pin2;
      int ccwchar;
      int cwchar;
      volatile unsigned char state;
    rotariesdef rotaries[NUMROTARIES] {
      {0,1,16,17,0},
      {2,3,18,19,0},
      {4,5,20,21,0},
      {6,7,22,23,0},
      {8,9,24,25,0},
    #define DIR_CCW 0x10
    #define DIR_CW 0x20
    #define R_START 0x0
    #ifdef HALF_STEP
    #define R_CCW_BEGIN 0x1
    #define R_CW_BEGIN 0x2
    #define R_START_M 0x3
    #define R_CW_BEGIN_M 0x4
    #define R_CCW_BEGIN_M 0x5
    const unsigned char ttable[6][4] = {
      // R_START (00)
      {R_START_M,            R_CW_BEGIN,     R_CCW_BEGIN,  R_START},
      // R_CCW_BEGIN
      {R_START_M | DIR_CCW, R_START,        R_CCW_BEGIN,  R_START},
      // R_CW_BEGIN
      {R_START_M | DIR_CW,  R_CW_BEGIN,     R_START,      R_START},
      // R_START_M (11)
      {R_START_M,            R_CCW_BEGIN_M,  R_CW_BEGIN_M, R_START},
      // R_CW_BEGIN_M
      {R_START_M,            R_START_M,      R_CW_BEGIN_M, R_START | DIR_CW},
      // R_CCW_BEGIN_M
      {R_START_M,            R_CCW_BEGIN_M,  R_START_M,    R_START | DIR_CCW},
    #else
    #define R_CW_FINAL 0x1
    #define R_CW_NEXT 0x3
    #define R_CCW_BEGIN 0x4
    #define R_CCW_FINAL 0x5
    #define R_CCW_NEXT 0x6
    const unsigned char ttable[7][4] = {
      // R_START
      {R_START,    R_CW_BEGIN,  R_CCW_BEGIN, R_START},
      // R_CW_FINAL
      {R_CW_NEXT,  R_START,     R_CW_FINAL,  R_START | DIR_CW},
      // R_CW_BEGIN
      {R_CW_NEXT,  R_CW_BEGIN,  R_START,     R_START},
      // R_CW_NEXT
      {R_CW_NEXT,  R_CW_BEGIN,  R_CW_FINAL,  R_START},
      // R_CCW_BEGIN
      {R_CCW_NEXT, R_START,     R_CCW_BEGIN, R_START},
      // R_CCW_FINAL
      {R_CCW_NEXT, R_CCW_FINAL, R_START,     R_START | DIR_CCW},
      // R_CCW_NEXT
      {R_CCW_NEXT, R_CCW_FINAL, R_CCW_BEGIN, R_START},
    #endif
    byte rowPins[NUMROWS] = {21,20,19,18};
    byte colPins[NUMCOLS] = {15,14,16,10};
    Keypad buttbx = Keypad( makeKeymap(buttons), rowPins, colPins, NUMROWS, NUMCOLS);
    Joystick_ Joystick(JOYSTICK_DEFAULT_REPORT_ID,
      JOYSTICK_TYPE_JOYSTICK, 25, 0,
      false, false, false, false, false, false,
      false, false, false, false, false);
    void setup() {
      Joystick.begin();
      rotary_init();}
    void loop() {
      CheckAllEncoders();
      CheckAllButtons();
    void CheckAllButtons(void) {
          if (buttbx.getKeys())
           for (int i=0; i<LIST_MAX; i++)
               if ( buttbx.key[i].stateChanged )
                switch (buttbx.key[i].kstate) {
                        case PRESSED:
                        case HOLD:
                                  Joystick.setButton(buttbx.key[i].kchar, 1);
                                  break;
                        case RELEASED:
                        case IDLE:
                                  Joystick.setButton(buttbx.key[i].kchar, 0);
                                  break;
    void rotary_init() {
      for (int i=0;i<NUMROTARIES;i++) {
        pinMode(rotaries[i].pin1, INPUT);
        pinMode(rotaries[i].pin2, INPUT);
        #ifdef ENABLE_PULLUPS
          digitalWrite(rotaries[i].pin1, HIGH);
          digitalWrite(rotaries[i].pin2, HIGH);
        #endif
    unsigned char rotary_process(int _i) {
       unsigned char pinstate = (digitalRead(rotaries[_i].pin2) << 1) | digitalRead(rotaries[_i].pin1);
      rotaries[_i].state = ttable[rotaries[_i].state & 0xf][pinstate];
      return (rotaries[_i].state & 0x30);
    void CheckAllEncoders(void) {
        unsigned char result = rotary_process(i);
        if (result == DIR_CCW) {
          Joystick.setButton(rotaries[i].ccwchar, 1); delay(50); Joystick.setButton(rotaries[i].ccwchar, 0);
        if (result == DIR_CW) {
          Joystick.setButton(rotaries[i].cwchar, 1); delay(50); Joystick.setButton(rotaries[i].cwchar, 0);
  19. dualin
    dualin Member
    Cáceres - Spain
    - 41Coins
    Anyone can explain what is chained for the encoders? I make work the rotarys perfectly but the cst288 don't work fine. I can get only one pulsation every four.
    Regards
  20. ozkan memisoglu
    ozkan memisoglu New Member
    87Coins
    How did you connect your Arduino Pro Micro to Arduino Leonardo. Can you show with diagrammatize thank you so much sorry for my english.
