RC Model for Motion Simulation
Discussion in 'SimTools compatible interfaces' started by eaorobbie, Jul 17, 2013.
  1. lizwqd
    lizwqd New Member
    Beijing
    52Coins
    154,418Coins
    +11,181 / 57 / -2
    Google Translate -
    I am a newbie, I have purchased the simtools and race07 game plugins, I use RC_Sim_Model ino, and wired correctly, running the game, but I have no reaction to the motor, I don't know where the problem is, ask for help, thank you
    As per the forum rules you need to include English, particularly when seeking assistance, you can use Google Translate, as I have done for you: https://www.xsimulator.net/community/threads/forum-rules.9527/
    Regarding your question The difference from SimTools 1.3 to SimTools 2 in setup is that in the Interface Settings instead of axis defined like this <Axis1> it now has designate grouping for a or b in SimTools 2 for each axis assignment, like this <Axis1a>
    So in your case it should be R<Axis1a>~L<Axis2a>
  3. lizwqd
    lizwqd New Member
    Beijing
    52Coins
    Thank you for your reply. I have successfully established the connection. I will reply in English. Thank you.
  4. MrJack
    MrJack New Member
    184Coins
    2DOF, SCN5
    I use a 2dof simulator with 2 scn5 and I want to use in addition 2 servo rc, for testing a harness tensioner.
    The arduino code works, the servo move when I test Ard IDE with RCModelDebugMode.ino, but nothing in Simtools with RCModelSimToolsMode.ino .
    Is it possible to addition servo rc and scn ?
  5. Poo9jao
    Poo9jao I Like all Mod
    Coppy Machine Service Engineer
    Bangkok Thailand
    146Coins
    I'm too
    154,418Coins
    +11,181 / 57 / -2
    You can use @eaorobbie's code for servos, in SimTools 2 there is a slight Interface change, from this R<Axis1>~L<Axis2>~ to this R<Axis1a>~L<Axis2a>~
    https://www.xsimulator.net/community/threads/2dof-simulator-servo-model.6851/#post-77270
  7. MrJack
    MrJack New Member
    184Coins
    2DOF, SCN5
    Ah yes .. I test, thank you for your reply .
  8. MrJack
    MrJack New Member
    184Coins
    2DOF, SCN5
    It works :)
    Do you think it's possible to modify easily the RCModelSimToolsMode code so the servo (My servo rc have 180° rotation) position in Simtools has to be at 0° and not to 90° ?
    If I use only for surge effect (and just brake effect) with 90° initialization , the servo uses half of capacity with brake effect .
  9. Pramuuditha Kumara
    Pramuuditha Kumara Member
    61Coins
    i have done same setup, but still no movement on the motors when out out put testing
    can you please send me the image of the sim tools setting
    please help me to get ready this setup....
    i attached my current setup for reference....
    Please help me.....
    Thanks ....
  10. yobuddy
    51,665Coins
    @Pramuuditha Kumara,
    Your interface output line is wrong.
    You have "~R<Axis1a>~L<Axis2a>~" and it suppost to be "R<Axis1a>~L<Axis2a>~"
    You have a extra leading "~"
    Take care,
    154,418Coins
    +11,181 / 57 / -2
    That advice was also provided in an earlier post:
  12. Pramuuditha Kumara
    61Coins
    hi @yobuddy
    i have changed it out put setting like this R<Axis1a>~L<Axis2a>~
    still i have no any changes on output testing
    but when i start out put testing both motors are start moving with out control and no action when i move sliders
    is there any other things to check
    Please help.....
  13. insanegr
    insanegr !N$@n€
    Athens
    16,726Coins
    you have to configure the default profile in axis assignments so you can test output with sliders
  14. Kenza
    Kenza New Member
    126Coins
    Hello folks ! I did everything needed for the miniature plateform. I used the right script and everything but my servos don’t reply instantaneously.. :/
    Do you know what’s the problem ???
  15. yobuddy
    51,665Coins
    @Kenza,
    Can you post some screenshots of your settings?
    Maybe to much smoothing is applied?
    SimTools v2.4 has a much better smoothing filter btw (almost ready for release i think).
    Take care,
  16. FoxONe42
    FoxONe42 6DOF newbie
    Flight simulator engineer
    Nantes France
    102Coins
    Arduino, 6DOF
    I had a similar issue when I started using my RC 6DOF platform as well. Figured out that Malwarebytes software was the guilty one. I just turn it off any time I use the platfom now.
  17. Death Race
    Death Race New Member
    84Coins
    hello guys,, am a new member with you ,, i need to build 2DOF with big servo motors any advice?
    where i can find the final working code ?
    @noorbeast
  18. noorbeast
    154,418Coins
    +11,181 / 57 / -2
    Best to start your own build thread and specify exactly what motors you plan to use.
  19. Death Race
    84Coins
    i tested this and worked,, i need now to build the big one with high torque server motor ?? does this code support big motors ?
    @noorbeast
    154,418Coins
    +11,181 / 57 / -2
