Question GAMEVIBE ready PROFILES?
Discussion in 'Official Companion Apps' started by paulopsx2, Jul 20, 2018.
  1. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    hi for all.
    Just idea.. for all of us. Is it possible, to put GAMEVIBE profiles GET READY for some games? Like a THE CREW 2, PROJECT CARS 2, or others? Something like simvibe? Choose the game, click and have fun? Maybe try to put this file on GAMEVIBE plugin packages?? I confess... create 1 by 1 its cool, but im tired.. rs..
  2. yobuddy
    51,237Coins
    The problem is you can have quite a few different configurations on setup.
    But the Hi/Low profiles can be included in GameVibe itself if people post them.
    There files can be found here:
    "C:\Users\(your user folder)\AppData\Local\GameVibe\HiLowProfiles"
    There is another problem thou, most people only setup what they need, and not all possible vibe's
    There still is not allot of people with 3d vibe setups for instance.
    Take care,
  3. paulopsx2
    brasil
    647Coins
    hum.. good point. I started new config for the crew 2, but only 4 effects.. collisions. road detail and turbulence (?? ). Ok.. no chassis for bumps, or for individual tires... so i try to put major effects on this 4. Result its.... "interesting", but
    There are some options missing, as I see in the simvibe ... harmonicas, by tire, etc.
  4. yobuddy
    51,237Coins
    But your trying to compare a 'wysiwyg' app to something that can be used for any game plugin now and in the future.
    GameVibe is completely configurable, from what every effect sounds like, to how every effect is used.
    And a plugin writer can easily add GameVibe support, without any altering of the raw telemetry game data. leading to a bunch of game support for GameVibe over time.
    Also, GameVibe effects can easily be expanded, like adding landing gear etc..
    btw, the tire affects, I'm guessing is 3D Chassis output in GameVibe.
    But not all games provide this data (shock position per wheel).
    In the end thou, we both have the same game data to work with.
    So no matter what you call things, there is only so many ways to do things with this data.
    So I would expect much of the same types of results.
    Also, keep in mind that using too many effects on the same set of kickers will just produce a mess.
    Unless you have a bunch of kickers, only using a few may work better on some setups.
    Take care all,
  5. paulopsx2
    brasil
    647Coins
    yeah !! for shure. gamevibe its a AWESOME soft. No doubt. Simvibe its... " interesting" , but at 89$ and ULTRA LIMITED games list, isnt great idea for all of us. tks
  6. lawmankyo
    lawmankyo New Member
    121Coins
  7. paulopsx2
    brasil
    647Coins
    i know. I refer to ready files, for download, or something else.
  8. yobuddy
    51,237Coins
    Should anyone actually setup all vibes for a game and wants to post there settings file, the file can be included in the next release.
    Take care,
  9. CQeNS
    CQeNS New Member
    50Coins
    When I was setting up my GameVibe for the first time, I used the GameVibe Manual and RPM setup was pretty straightforward. However other vibrations (Chassis, road detail) were bit more tricky and I wish a list of recommended 1-2 sound options were provided that have worked the "best" or represent the vibration in the proper way.
