Question What exactly do the sliders in the washout filter do?
Discussion in 'SimTools DIY Version' started by Alexander Asner, Jul 21, 2018.
  1. Alexander Asner
    Alexander Asner New Member
    271Coins
    3DOF, SCN5, SCN6
    Sorry if this is a dumb question but I did not find the answer.
    What exactly does the gain slider do and how does it relate to the tuning center values. What happens if I push it to the right, what happens if I leave it to the utmost left side?
    What if I do not move the washout button? There will be no washout and the axis just follows the movement
    ? What do I alter with the slider? The washout speed?
    Help highly appreciated as I am just guessing.
    153,986Coins
    +11,162 / 57 / -2
  3. yobuddy
    51,561Coins
    (Washout) Gain – This is how much we will react to changes in the input from the game. If your simulator is not moving enough from the output from the game, Increase this value.
    (Washout) Return – This is how fast we try to return to zero after a movement has occurred. If your simulator is not homing (re-centering) fast enough after a movement, Increase this value.
    The Washout Filter is needed when your DOF input fails to return to center after the force is applied to the Axis.
    Example: when car's rear end slides out. The Axis is left in a non centered position. If the car then needs to slide out in the same direction again, there would be no room left for the needed travel. To overcome these circumstances, we use a washout filter as to slowly move the axis back to center without the rider’s knowledge of it occurring. A Gain of 1 or above must be used for the Washout system to be considered active. A setting of 50% for both Gain and Return is a good place to start for any game.
    Take care,
  4. Jon B.
    Jon B. New Member
    136Coins
    Hello
    Ive tried this washout return setting at 0%, 1%, 50% and 100% in asseto corsa and my chair will not reenter. Im leaned over in every straightaway. Any ideas of a solution. Getting my motion dialed is driving me nuts. I've spent over a week on it and i keep going in circles. Thanks.
    153,986Coins
    +11,162 / 57 / -2
    You should not really need to use washout, gain and return in a race car motion profile, they are more for flight sims.
    Follow these steps and do one axis at a time to refine a motion profile: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
    • Disagree Disagree x 1
  6. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,839Coins
    DC motor, 6DOF
    @yobuddy,
    I have the feeling that the gain max value is not big enough to bring back the cue to the center.
    Could this be the reason why the platform does not always return to the center like I would expect??
    Best
  7. yobuddy
    51,561Coins
    @hexpod,
    The Gain Value is how much we will react to changes in the input from the game.
    Return is how fast we try to return to zero after a movement has occurred.
    If your not returning to center fast enough, increase Return and/or lower Gain .
    Take care,
  8. AussieSim
    AussieSim Member
    Australia
    1,452Coins
    Sorry to butt in to this thread.
    My interpretation of the above is the washout return is to restore a given axis back toward zero where there is a regular positive signal.
    For example in an oval race track there will frequently be a Yaw force, which will reach the axis limit very quickly.
    Is there a way to slow down the natural return, for example a harness tensioner belt without elasticity. Upon braking/surge the belts tighten quickly, but upon release of the brake I don't want the harness tensioner to release pressure immediately. Rather to gradually reduce tension.
    Is that possible with the washout filters ?
  9. hexpod
    berlin
    7,839Coins
    DC motor, 6DOF
    @yobuddy,
    Sorry but I would need a bit more pedagogy concerning this filter.
    If as I expect, the gain slider concerns a certain cut-off frequency in what should be a simple high-pass filter (low-cut filter), what exactly does the setting 1 and the setting 100?
  10. BlazinH
    16,691Coins
    According to yobuddy's description of the washout filters no they don't work that way but should. It sounds like this system was designed before we had extra1 for traction loss and yaw velocity and people had to use yaw. But what we need now is a way to slow down the natural return of traction loss etc. if you would prefer not to have an abrupt return to center. I prefer the abrupt return for traction loss myself however making it function like all other G forces do without filters. For flight though washout filters would be appropriate.
  11. hexpod
    berlin
    7,839Coins
    DC motor, 6DOF
    How I can bring this to the center buddy? I tried gain 1 and gain 100
    Best
  12. hexpod
    berlin
    7,839Coins
    DC motor, 6DOF
    @yobuddy,
    In the video above, please pay attention to the have slider in heXpod. As long as you modify the cue in the upper or lower range the rerun function doesn't bring it back. (It should). The platform returns to the center only when I stop moving.
    Do I missing something? Can you see the issue?
    Best
  13. yobuddy
    51,561Coins
    It's probably from the sin wave in the experimental plugin you are running?
    Please remove the Rpm output from heave to see what happens buddy.
  14. hexpod
    berlin
    7,839Coins
    DC motor, 6DOF
    I don't understand what it has to do with the X-plane plugin?? Could you please watch again the video test above, I am testing the heave output by moving it with the mouse!
    Logically it should return to the center. Any explanation?
    Best
  15. hexpod
    berlin
    7,839Coins
    DC motor, 6DOF
    @yobuddy, to be sure I've checked also with the previous version of the plugin. Same strange behaviour.
    As soon there is some cue change, the signal doesn't return at all.
    Could you check it please what's wrong there?
    We cruelly need this feature to maximize our 6dof's workspace.
    Thank you
    Best
  16. hexpod
    berlin
    7,839Coins
    DC motor, 6DOF
    Why the hell this math is sending the cue to the edge??
    Please watch:
    Best
  17. BlazinH
    16,691Coins
    It appears that if the dof doesn't return to center before a new setpoint is given the filter is not properly accounting for this and instead adding outputs together.
  18. BlazinH
    16,691Coins
    Could it be because heave is a g force and not angular? A more detailed description of the filters would be nice. Above its stated it returns forces to center but the example used is angular.
  19. yobuddy
    51,561Coins
    @hexpod,
    No worries buddy.
    We just need some heave washout tuning it looks like.
    There is actually 2 washout algorithms here.
    One for degrees and one for g-forces.
    I spent most of my time on the traction loss g-force algorithm.
    Where the degree algorithm was mainly tuned for yaw.
    We can work on it this weekend on skype and see if we can tune it in better for heave.
    Take care!
  20. BlazinH
    16,691Coins
    I am/was confused by this statement:
    With forces you can't home any faster than what the game output is already doing can you? Now I know you recommend starting out with both at 50% but in my mind that's just muddying up the natural motion output before you even get started tuning. How am I wrong here @yobuddy?
    p.s. If this is really how you should do it I recommend making 50% zero then using -50 to +50 as that would be less confusing and a more accurate representation imo.
