Showroom DIY Fiberglass 360° motion sim.
Discussion in 'DIY Motion Simulator Projects' started by Wagnard, Jul 25, 2018.
  1. Wagnard
    Wagnardsoft
    Canada, Quebec, Mirabel
    5,173Coins
    Hi everyone,
    First sorry for my poor English, it is not my first language, I'll do my best to write correctly.
    I've been lurking here for +-2 years dreaming of your simulator. Especially @SilentChill one.
    We live in the province of Quebec (Canada) in a city call "Mirabel en haut"
    Then last year on spring we (my father and me) began a prototype and here is what we have so far...
    Yes, we are aware this is kinda a mess in different sectors especially the wiring.
    It is still an unfinished prototype (wood stuff will be changed to fiberglass) and we intend to make it cleaner in the future.
    Currently we have pitch/roll/yaw. We are thinking on adding sway , surge and heave if possible.
    Here is some key part:
    Made of fiberglass.
    Universal joint.
    Actuators are actually 2 ABS tube with RS-775 (cheap) motor running at 18k rpm but lowered with gearbox. Initially with cheap 10 turn POT, now with 10 turn hall effect (man theses thing are good and robust !)
    -self created slip ring for the 360 yaw stuff.
    More details to come...
    Hope you will like, feel free to comment.
    Here are some videos :
    • Like Like x 5
    • Creative Creative x 3
  2. ferslash
    ferslash Active Member
    4,798Coins
    woow, i saw your motor 775 and they do not seam expensive at all, what kind of gear box did you use with them... (i thing you just made the cheapest actuator around here) please share us how you made your actuator and how powerfull it is
    best regards from mexico
    fer
  3. Wagnard
    Wagnardsoft
    5,173Coins
    I used the gearbox that came with them from a circular saw (18v) a Ryobi one if I remember.
    Actuator is made with
    -the quite standard , SFU1605 ballscrew
    -2 ABS tube one 1-1/4" the others, (will have to check to be sure, but I think its a 2") it as to be enough space for the rack.
    -3d Printer to print spacers here and there and to print the rack for the POT (Hall effect in our case)
    -Some screws and "Tap" at the right place.
    1 major weakness in our build ,that we will change in the future, is that the coupling is 3d printed with PETG. and all the pull and push forces are handle by it. But so far only broke one and we changed the design of it and it never broke again.
    So we expect to make a more standard actuator like some are doing here that will not put forces on the coupling but we will still use are rack idea instead of timing belt and pulley.
    as for it's strength, we didn't do many scientific test on that, we just put the actuator to the test and with a universal joint in the middle, our system has been able to play with a 240lbs player.
    We do plan in the future to replace the ABS tube with carbon fiber for look and peace of mind ;)
    On the motor picture, it is not PS-xxxx its RS-775-9013
    Our second motor is not the 9013 its the RE-775-WC-8514 (what we found on the second saw :p but it is equivalent.
    I'll give details on the gearbox ratio later when I check it up. My memory is bad and didn't take picture that time.
    I also added a picture of our inner slipring for the 360 yaw.
  4. ferslash
    4,798Coins
    do you think that if you connect directly the motor without the gearbox it would to the work (i mean since the ball-screw it self is some kind of reductor?)
    fer
  5. Wagnard
    Wagnardsoft
    5,173Coins
    Probably not as I would loose a lot of torque and the motor is too fast.
  6. mariano68
    mariano68 Active Member
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
    I was thinking the same, but easier and cheaper to get a reducer, is to make one, cause you just need to go 3:1 or 4:1 as this motors goes from 9000 to 19000rpm, just a belt and a pulley... would be nice to get one to play. :)
    https://www.robotshop.com/en/banebots-rs-755-18v-19500-rpm-brushed-dc-motor.html
  7. Edaurdo
    Edaurdo Member
    Buenos Aires, Argentina
    190Coins
    Congratulations @Wagnard !! It's a great job!
    Do you know what is the weight that can load the linear actuator?
  8. Edaurdo
    Edaurdo Member
    190Coins
    @Wagnard, are you using SMC3?
    Have you tried it with your simulator?
  9. Wagnard
    Wagnardsoft
    5,173Coins
    Yes using smc3 (with some. Modification to have an lcd)
    I have not tested the force of the actuator independently All I know, is that a 240lbs person had no problem on it.
    There is a universal joint so we can say that the actuator can handle at lest half of the 240lbs
  10. Edaurdo
    Edaurdo Member
    190Coins
    Perfect! When you say that you have made a modification to SMC3 to have an LCD, is it a screen ?. What do you mean? I do not understand what kind of modification you might need the software
    Apologies for my ignorance
  11. Edaurdo
    Edaurdo Member
    190Coins
    On the other hand, I do not see in the images if you used limit switches ... I do not understand what the electrical connection would be like, but I have seen in other developments that are used.
  12. Wagnard
    Wagnardsoft
    5,173Coins
  13. Edaurdo
    Edaurdo Member
    190Coins
    I congratulate you on the development of these actuators. I hope to create similar ones soon.
    Has comprado la varilla roscada o las has hecho tornear?
  14. Wagnard
    Wagnardsoft
    5,173Coins
    Here is a small video of the changes in the front that we did recently.
    Much better looking.
  15. Wagnard
    Wagnardsoft
    5,173Coins
    Just a little video of my playing today.
  16. Wagnard
    Wagnardsoft
    5,173Coins
    We added recently the surge acceleration to our sim.
  17. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,044Coins
    3DOF, DC motor, Arduino, 6DOF
    Man, you are violent with your simulator.
    Wonder it does not break more often.
  18. Wagnard
    Wagnardsoft
    5,173Coins
    More violence :p
    We added the sway recently.
    • Like Like x 5
  19. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,044Coins
    Oh! Man! Canadian hockey sticks and duck tape.
    That thing is terrifying.
  20. Will974
    Will974 Active Member
    Industrial Ingeenering Teacher
    Reunion Island
    953Coins
    Awesome and original rig :)
