Question for people using wiper motors or scooter motors
Discussion in 'DIY Motion Simulator Projects' started by wthierry, Sep 12, 2015.
  1. wthierry
    wthierry Member
    748Coins
    3DOF, Arduino
    So I am just starting a joyrider build, but thinking a bit in the future, how do the electronics know the positioning of the motors? If they are wiper motors or scooter motors I would think the electronics need some kind of encoders to properly position the motors. Am I missing something, or is there something I dont understand....
  2. wthierry
    wthierry Member
    748Coins
    3DOF, Arduino
  3. RufusDufus
    RufusDufus Well-Known Member
    Adelaide Australia
    16,307Coins
    Hi @wthierry, Most people use a resistive POT (potentiometer) for the position feedback somehow mechanically connected to the the motor shaft. There are lots of different ways of doing this, but again the most common and probably the easiest is to connect the POT shaft direct to the motor shaft with a suitable coupling. Others use gears or belts or other ingenius ideas. If you search some of the existing designs you are sure to find examples. It's a pretty common design topic.
    152,553Coins
    +11,087 / 56 / -2
    You can find a lot of this sort of information in the FAQs: http://www.xsimulator.net/community/faq/
    First there are some common terms and acronyms that are used, so if you are trying to work out what something means then look it up in the Glossary: http://www.xsimulator.net/community/faq/glossary-of-acronyms-and-names.66/
    Here is a summary of the basics of motion control: http://www.xsimulator.net/community...on-simulation-control-basics-how-it-works.38/
    Specific topics are covered in more details in the various FAQ sections, but one that you will find handy is the Building Resources section: http://www.xsimulator.net/community/faq/building-resources.12/category
    Various ways to attach potentiometers are covered here: http://www.xsimulator.net/community/faq/how-to-connect-protect-a-potentiometer.13/
  5. bsft
    As for pot mounting, drill a hole in the back of the motor bolt, and slip the pot shaft in, then instead of drilling right through like I did (pain in the butt) tap a 3mm hole in the top part of the hex on the bolt and screw in a 3mm grub screw or bolt to hold the shaft steady.
    As for wipers on a joyrider,
    ignore the information about how I mounted a pot, this is old and back of the motor shaft works better
  6. wthierry
    wthierry Member
    748Coins
    3DOF, Arduino
  7. bsft
    Yes they would
  8. Nick Moxley
    The 2nd rig i built for a buddy uses those motor's. No issues really, But buddy hasn't played with it much since i built it (less than an hours worth) :eek: :rolleyes::oops::confused:
  9. wthierry
    wthierry Member
    748Coins
    3DOF, Arduino
    My main concern is reusability. I want to build a joyrider because its a relatively simple rig and inexpensive. But I want to move up to a 3dof or even a stewart type design in the future, and wonder if these are good enough to take along to another project. Or would I be better off selling the Joyrider with motors and starting fresh?
    152,553Coins
    +11,087 / 56 / -2
    I suspect you would be better off starting fresh when you get to that stage, by then you will have more experience and likely will be more ambitious with your next project. 3DOF and especially 6DOF require some serious hardware.
  11. bsft
    choice is yours, although I re-used the wipers off my old joyrider onto the next 2 2 DOF sims.
    If you are worried about the motors, use 50:1 or 60:1 boxes on them for greater torque.
    For 3 DOF (2 DOF balanced and drift) , these are fine,
    For 3 DOF lift, look at larger powerful motors, like 24 or 240v motors.
    For 6 DOF, several ways, 12v motors on custom actuators @SeatTime I recall was up to something, or 240v motors.
    Just for reference, my joyrider would have cost me more than the next build if I had to buy the steel. I used a LOT more steel in my joyrider than my 2 DOF balance sim.
  12. wthierry
    wthierry Member
    748Coins
    3DOF, Arduino
    Im doing the PVC joyrider, at least for the outer frame, maybe the seat contraption will be steel havent got there yet. But will order a couple of those motors and finish my frame and attach caster bearings in the meantime
  13. wthierry
    wthierry Member
    748Coins
    3DOF, Arduino
    One more question, I have searched the forums, but not finding much info on how to mount say a bike chain gear to an arbitrary motor shaft. Also, where to find these kinds of items that are fit to mount to motor shafts.... thanks in advance.
    152,553Coins
    +11,087 / 56 / -2
  15. SeatTime
    You can do something like this with standard bike parts (from my old sim)
    or purchase a motor with the cog already fitted - similar to what is shown in this link: https://www.motiondynamics.com.au/united-my6812-12v-dc-100w-2750-rpm-electric-motor-chain-en.html
  16. wthierry
    wthierry Member
    748Coins
    3DOF, Arduino
    so many decisions to make... Frame will hopefully be done this weekend, so going to order some motors tonight... Thanks for all the tips guys! Will post some pics over the weekend of how the build is going.
  17. Gadget999
    12,035Coins
    I use wheelchair motors
    Powerful quiet and have a built in gearbox
