Bought 4 aurasound bass shakers, what else do i need for it to work other than simvibe/gamevibe?
Discussion in 'New users start here - FAQ' started by Mpmo, Oct 22, 2017.
  1. Mpmo
    Mpmo Member
    United Arab Emirates
    1,289Coins
    In the metal base? It seems like you have attached the bass shaker to some kind of mount no?
      954.7 KB
      695
  2. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
  3. paulopsx2
    brasil
    647Coins
    This one on pic its a right shake from chassis. Not pedal. Pedal shaker its under metal plate.
  4. Mpmo
    Mpmo Member
    1,289Coins
    hey! so i tried simvibe and it's freaking goood, but for example when the front of my car hits something, i feel vibration in the rear wheels much more lol.. and when i hit the front right side of the car for example, again i feel vibration in all sides. How do you fix this? do you have recommended settings? cause i want to feel the car impacts ONLY where they hit. So if i go reverse and hit something, i just want to feel the impact from the back, etc..
    153,764Coins
    +11,149 / 57 / -2
    Just to clarify, are you using SimVibe or Game Vive, as they are two different programs, with Game Vibe being part of SimTools.
  6. paulopsx2
    brasil
    647Coins
    It depends on many things. if it is gamevibe, you have to create the effect, it only comes with some generic things. if it is simvibe, the effects come ready, then you would have to observe if the connections of your cabling are correct, positioning and division in the sound control of windows ,,, here so far all that game in simvibe are perfect.
  7. Mpmo
    Mpmo Member
    1,289Coins
    Simvibe
  8. Mpmo
    Mpmo Member
    1,289Coins
    I’m using simvibe. So you haven’t adjusted any settings in control center? Like you didn’t tune the effects like impacts or anything?
  9. paulopsx2
    brasil
    647Coins
    if you need, just make your own adjusts.
