Url to Carbon fiber actuator not working?
Discussion in 'DIY Motion Simulator Projects' started by Johan Andersson, Aug 10, 2018.
  1. Johan Andersson
    Johan Andersson New Member
    177Coins
    Hi all,
    I'm trying to find info on the DIY carbon fiber actuators used by @SeatTime and @SilentChill (atleast that's what I belive they use?) but I can't seem to access that part of the forum. Any reason why? And if it's not what they use, which guide should I follow?
    Also, what is the main reason to use actuators instead of a motor with a lever?
    Thanks!
    • Old Old x 1
  2. SeatTime
    There are a few reasons:
    • Motion is linear throughout the actuators length.
    • Most gearboxes have 'play' between the gears so fine movements can be lost, ballscrew basically have none.
    • large movements are possible without reducing torque, which would be the case with long levers.
    • Ballscrews have a much higher efficiency then a worm drive.
    See @wannabeaflyer2 excellent actuator design drawings.
    153,758Coins
    +11,149 / 57 / -2
    @SilentChill's 6DOF thread is here: https://www.xsimulator.net/communit...bertooth-2x60s-was-mms-and-arduinos-osw.6948/
    @SeatTime collapsed all of his various sim project threads into one, which can be found here: https://www.xsimulator.net/community/threads/seattimes-sims.11757/
    You can find other 6DOF projects and information in the FAQs: https://www.xsimulator.net/community/faq/6dof.22/category
    And even more 6DOF project and DIY linear actuator designs by using the Custom Google Search box near the top right of many pages.
  4. Johan Andersson
    177Coins
    Thanks! :)
    Very clear and helpful answers.
    I haven't seen @wannabeaflyer2 design yet. Started reading @Hoddem 's thread and those looked really nice, but I'm deffinatly going to be reading in to this topic alot more.
