Question Tuning center tick marks missing?
Discussion in 'SimTools Pro & Entertainment Version' started by fsutton, Aug 12, 2018.
  1. fsutton
    fsutton Member
    323Coins
    I've read several threads that indicate that I should be able to manually edit min/max values by unchecking a tick box in tuning center. The only thing I can do is change the state (balance capture off). I want to adjust surge. How do I do this, my version looks different than what I've seen in the other threads.
    154,478Coins
    +11,184 / 57 / -2
    The box next to the axis (Balance = green by default) can be clicked on, it then changes to Capture (changes to blue) or what you want, which is Off for manual entry (pink).
  3. fsutton
    fsutton Member
    323Coins
    Setting the box to pink still doesn't allow me to manually change the value. The white min and max value boxes are still locked. You can see it's still greyed out below. Not sure what I'm missing.
  4. fsutton
    fsutton Member
    323Coins
    Disregard my last post. I didn't realize that I had to also click on the capture button. All is well!
