Recommended specs for control pc running XSim2 ?
Discussion in 'Force-Profiler Simulator Control' started by egoexpress, May 25, 2009.
  1. egoexpress
    egoexpress Active Member
    Germany - Frankfurt/M
    421Coins
    Will a Pentium IV mobile with ~2GHZ be enough for a math calculation speed of 1-2ms, even if I have a full grid of math table entries?
    Or even less processor speed?
    I am planning to use an old laptop with nothing more installed on it than WinXP and XSim2, as it bothers me that I have to leave the active game window to tweak the profiles.
    regards
  2. RaceRay
    Hamburg, Germany
    23,876Coins
    Hi Chris,
    i will test it today evening. I got a Pentium celeron 1,6Ghz Laptop at home. (USB 2.0, 1Gbit ethernet (will use only 100Mbit)
    It´s without any special software, or services, so a test should be very meaningful. The only thing missing is a full grid of complex math entries. Do u got some examples i can use?
    regards
    René
  3. RaceRay
    Hamburg, Germany
    23,876Coins
    Ok, i´ve done it as you said:
    Calculations/sec 600.000 - 700.000
    Math engine cycles 160.000
    synaptrix output/sec 900
    98 - 100% CPU load on the profiler core, but the game runs smooth on the other core :) No delays or freezes in switching between game, profiler, and windows xp
    Ähem, i only use a core2duo e4300, what´s wrong with my values, seems to be too much.
    Next, i publish benchmark for pentium M laptop 1,6Ghz.
    Edit: CPU load on the screenshot is better than wrote, because i made the screenshot with focus on the profiler not the game.
    regards
    René
  4. RaceRay
    Hamburg, Germany
    23,876Coins
    Seems to be windows xp (32) and Vista (64bit) problem...
    Would be interesting to know what calculations/sec other users get.
    Please publish your OS, Hardware configuration and math outputs and synaptrix.
    regards
    rené
