Project cars 2 plugin help
Discussion in 'SimTools Plugins' started by PIM1, Aug 14, 2018.
  1. PIM1
    PIM1 VR Racer
    Fitness Instructor
    United Kingdom
    150Coins
    2DOF, SCN6, Motion platform
    Hi guys,
    I have Assetto corsa/iracing working with full motion and gamevibe. I cannot get PC2 to produce motion or gamevibe at all. I have the Project cars UDP PC plugin.
    I can get pc2 working with just motion with an old plugin but I so want to feel vibration whilst playing. I have contacted YoBuddy and he has suggested to turn on vibe after game has started but that has not worked. I have no coins to try another plugin (used them all on weeks pass).
    Any help would be great.
    Neil
  2. yobuddy
    51,099Coins
    I think the Project cars UDP PC plugin is a manual game plugin meant for consoles? (Xbox - PlayStation version of the game)
    Anyway, when you select the plugin in game manger does a play button show up?
    If so press that then play the game and it should work buddy.
    Let me know how it goes,
    152,355Coins
    +11,075 / 56 / -2
    Have you done the required settings in ProjectCars, see here for details: https://www.xsimulator.net/community/faq/projectcars.188/
  4. PIM1
    PIM1 VR Racer
    Fitness Instructor
    United Kingdom
    150Coins
    No play button I can see and yes I think it could be a console plugin :-(
    Motion is working great on old plugin but I need vibe like I have with iracing and Assetto.
    Let me know what you advise next.
    Neil
  5. PIM1
    PIM1 VR Racer
    Fitness Instructor
    United Kingdom
    150Coins
  6. MADERN
    MADERN Member Gold Contributor
    Decorater
    538Coins
    SCN5, SCN6, Motion platform, 4DOF
    hello everybody i hope somebody can help me i have simular issues with pc2,assetto corsa works perfectly when i change to project cars 2 i loose the motion on the front actuators ,traction loss works fine can not get the front to move its like game engine is turning off, when i check the output on the rig it all moves correctly ,i start pc2 and only traction loss is working when i come out of the game ,game manager is in output testing mode and is counting down to turn off when i turn output test on, the rig does not move, i have to restart game engine ,check output test and the rig moves as i would expect ,i start the game only to find the rig will not move its bin like this for 3 days now.i have tried another plug-in but still does not work ,i have also rolled back game engine to last week setting still won't works have checked setting in the game nothing has changed, has anybody got any ideas whats gone wrong
    thank you Dave
  7. misoswan
    misoswan Active Member
    1,032Coins
    3DOF, Arduino, JRK
    hi have problem plugin project cars 2 .I cant conected on game (game manager green not blue)tested eurotruck simulator 2 allwork correct.any idea thanks.Michal
  8. tomkil192
    tomkil192 Member
    Uk. London
    - 25Coins
    Michal, I have the same issue. I think you are using incorrect plugin. 2.0.5.5 is now available.
    Can you try it and let me know? I do not have enough coins quite yet to get it.
    good luck.
    Tom
  9. misoswan
    1,032Coins
    3DOF, Arduino, JRK
    Hi Tom yes problem solved (bad old plugin before I used)
  10. tomkil192
    tomkil192 Member
    Uk. London
    - 25Coins
