Joyrider model
Discussion in 'CAD / CAE - Outdated' started by Alle, Jun 13, 2008.
  1. RaceRay
    Hamburg, Germany
    23,877Coins
    Hi Alle,
    looks great.
    Than we will publish your model as part of the header graphics beside the simforce gt model. Do you wanna raise any objections about it? :)
    Kind regards
    René
  2. egoexpress
    egoexpress Active Member
    Germany - Frankfurt/M
    421Coins
    @Alle
    are you working on it still? We would like to add it to the forum header!
    I've tried to work it out some further, as it seems that you dont have time to work on it currently, but I wasn't able to open/import it correctly. The .dwg does not work at all for me, and the .sat does weird things to the model geometry while importing...
    Could you make a list of possible formats you can export with your Autocad version please.
    I could repair it manually, but this would take as much time, as making it from skratch.
    Regards
    Christian
  3. Mambo
    Mambo New Member
    Czech Republic
    288Coins
    Hi
    i dont have any problem open it with inventor so i export it for you in some others formats (sat - from inventor, proe granid and neu and step ). if it isnt works PM me and we can figure it out. I remeber that export to proe worked with one format.
    http://rs78cg2.rapidshare.com/files/136 ... raider.rar
  4. egoexpress
    421Coins
    @Mambo
    Thanks alot!
    The .stp (step) format works fine for me. Imported correctly as assembly file.
    Regards
    Christian
  5. eaorobbie
    20,488Coins
    bugger would like to reproduce this here in australia a complete design would be great thanks wd all
    :blush:
  6. bubbleman
    bubbleman New Member
    0Coins
    Hello Mambo, could you send me the project in Inventor format?
    thanks.
  7. Ben Heenan
    Ben Heenan New Member
    171Coins
    2DOF, Arduino, Joyrider
    I was just wondering whether anyone still had the CAD model of the Joyrider flight simulator, as it won't let me download it?
