  1. marco balletta
    marco balletta Member
    1,445Coins
    Do you guys need 4 more weeks starting from the day you posted this reply?
    Also, will the side bars motors of the base touch the ground when swinging around ?
    In the prototype it seems that part of the rig touches the floor when doing certain movements
  2. greatg67
    greatg67 Member Gold Contributor
    509Coins
    I have a 4 point harness that I want to use with my racing seat. Does anyone have any recommendations on how to attach the harness to a P3 system?
    153,770Coins
    +11,149 / 57 / -2
    As per my previous reply he simplest and most common way for most sims is to attach the two lap belts directly to the bottom frame and use a spring between the two shoulder straps and the bottom frame.
    But members such as @SeatTime have gone even further and created motion driven harness that loosen and tighten in response to motion: https://www.xsimulator.net/communit...int-harness-on-racing-seat.12331/#post-160962
  4. greatg67
    509Coins
    Thanks noorbeast! I just wanted to see if anyone with the same Sim as I have had any thoughts .
  5. Andy Booth
    Andy Booth Active Member
    Malaysia
    430Coins
    I have a bad left eye and I was concerned about VR with only one good eye. I bought the Rift DK 2 probably a year and a half ago to try and it turned out to be really just not worth it. Obviously you are not going to see 3D because you are only seeing one screen. Because you are only seeing one screen, the field of view is somewhat restricted. But the biggest problem I had was there were particular screens (usually windows screens etc) that were only displayed on one side. To see what was being displayed meant taking the headset off and looking through the headset with the other eye or removing the lens altogether and peering into the headset at the tiny image on the screen. Not impossible, but for me, it just wasn't worth it.
    Things may well have improved since the DK2 and the actual game screens were usually displayed on both screens anyway, but it wasn't really worth the effort for me.
    Hasn't stopped me looking at this generation of headsets. Waiting to try out a friends Rift to see if all my issues I had with the DK2 have been resolved.
    I suggest you try before you buy. But for me, I think head tracking is a better option, especially for flight sims. Just waiting for my EdTracker to turn up.
    Andy
  6. Andy Booth
    Malaysia
    430Coins
    I used ECCI 7000 force feedback wheel (Probably as heavy but not as much force) and HPI Pedals (heavier and similar forces) and I did indeed break my frame however DofReality did send me a replacement free of charge. The newer design is stronger so I doubt you will have any issues.
    Just get the rig balance right and you will be OK.
    Andy
  7. Benji85
    Benji85 Member Gold Contributor
    851Coins
    I have this rig and I attached lap belts to sides of seat - top of frame NOT bottom.
    I had it ties at the bottom to begin with and it felt awful when the seat rolled etc and the belt would slack and tighten .
    Worked much better when attacked to the seat as the pressure was then constant and even but I did attach the shoulder straps to the bottom non moving frame with a thick cable tie - no spring . Works great and if your strapped in properly the straps tighten (seat pitches forward)
    as you brake and it feels bloody good! ;)
  8. LesterCovax
    LesterCovax Mixed Reality Addict
    DevOps Docent
    North Carolina
    160Coins
    I barely see out of / use one of my eyes and had the same concerns with VR due to having issues with any 3D movie / content in the past. I don't race without my Vive now. If you have any vision in that eye at all it's insane how much benefit you get from the depth perception, let alone the immersion factor. I would at least find a friend that has one, or go to a store or something to try it out if you're still having doubts.
    The blind will rise again!
  9. LesterCovax
    DevOps Docent
    North Carolina
    160Coins
    Apparently my 1 minute to edit expired while appending the questions I forgot to ask in my previous comment...
    I came across the kickstarter for the 'Feel Three' motion platform today and it rekindled my need for a motion rig. Igor has been helpful when I've contacted him before but would appreciate some customer's opinions on a few things.
    1. Noise. The motors/actuators are supposed to be fairly quiet but I'm mostly concerned about the noise from the floor below. I'm worried about my downstairs neighbors having a conniption anytime I'm using it.
    2. Adjustability. Foot pedal shelf looks like it only adjusts 20-30°, so I doubt I'd be able to invert my pedals without getting a new set or an adaptor. Same thing for the wheel base shelf as I currently have a Playseat Challenge and the ability to change the angle of the wheel is pretty nice. I'm sure the stability of an H3 would make up for that though. Can I assume that as long as I have a chair on rails that I can customize it enough to my liking?
    3. Why P3 over H3? Have there been many cases of durability / performance issues with the H3 model? I'm 200lbs at my heaviest and the specs for power/torque are extremely close between the two, so is the extra 4° of movement and added power worth the extra cost? If it's just because the price differential wasn't a big deal to people, that's one thing, but I'd prefer to save a few bucks provided the H3 won't crash and burn.
    4. How easy is it to move around? I typically have my rig in front of a green screen setup but may occasionally need to move it in front of my desk. Curious if locking castors would be an option, or using furniture sliders, or if it's not hard to move by myself.
    Thanks in advance!
  10. Mousetrap
    Mousetrap New Member
    Retired EE
    Deep North of Minnesota, USA
    318Coins
    (According to FedEx) My 3P left Ukraine today (October 30) and is in France, scheduled for delivery tomorrow.
    Apparently, FedEx doesn't know that they have to wait for freeze-up before they can run the sled dog teams to deliver to northern Minnesota.
  11. LesterCovax
    DevOps Docent
    North Carolina
    160Coins
    Yeahhhh, you may want to contact FedEx to confirm the target address (if they'll let you) or contact Igor to make sure tracking information wasn't mixed up with a different order. I'm most impressed that they've somehow broken the space/time barrier by delivering it in the future (October 30) :p
  12. Mousetrap
    Retired EE
    318Coins
    Oops, my mistake. Should be today (August 30). I tend to get the vowel months confused. At least I didn't say April.
  13. optical10
    optical10 Member Gold Contributor
    694Coins
    I had a similar issue where my P3 to my UK delivery address was shipping to USA using TNT, but Igor to be fair did rectify the issue within five minutes, but you can imagine my worry!
    My main issue I think is a language issue as my previous emails asking confirmation of delivery date confirmed today (31st August) as delivery when in fact today was the shipping date, good job I didn't take the day off work especially leaving me a bit deflated but for 20th august order I shouldn't have expected it any sooner than 7th Sept as confirmed which is a good turnaround.
  14. mike523
    mike523 Member
    Chattanooga, TN
    448Coins
    I seem to have lost all "roll" in Assetto Corsa lately, has anyone else run into this? I've got roll on dof1 and dof2 set at 50 so I should be getting a fairly decent response. It works perfectly when doing output testing in simtools.
  15. Mousetrap
    Retired EE
    318Coins
    Impressed:
    1. P3 arrived this afternoon. Two days ago it was in France.
    2. Extraordinary packing by DOF. My compliments to the packer.
  16. greatg67
    509Coins
    Got my P3 setup. Installed the sw and ran the output test. I have no movement on the Yaw (slip) or heave axis? The back motor arm is not moving at all and is stuck in the back position?
    153,770Coins
    +11,149 / 57 / -2
  18. greatg67
    509Coins
    So, when the nP3 first powered on, the back (slip) actuator arm moved completely to the left (facing sim) causing the back of the sim to shift right. Using the default settings in Game Engine I cannot get the back actuator (slip) or heave to work?
    153,770Coins
    +11,149 / 57 / -2
    The DIR being checked orange or not determines which way an axis moves and yours are all mixed up @greatg67.
    There is a link in the first post of this thread to settings for some common games: https://www.xsimulator.net/communit...ject-cars-2-can-anyone-share-me-theirs.11273/
    But to get the most out of your rig you will need to learn how to develop motion profiles, as many for the DOFreality rigs have such high axis allocations that they will induce clipping, see here for the steps involved in refining a motion profile, and you do one axis at a time: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
    Once you get the basic issue and profile sorted you can refine traction loss even further: https://www.xsimulator.net/community/faq/traction-loss-in-simtools.175/
  20. greatg67
    509Coins
    That will work. But my traction loss actuator is not moving? When in game engine default settings I get no movement from this actuator. As I mentioned, when first power on, it moved to full left and hasn't moved since?
