Debugging tronic's AMC board
Discussion in 'New users start here - FAQ' started by stowaway, May 30, 2009.
  1. stowaway
    stowaway New Member
    Gold Coast - Australia
    1Coins
    I have finished putting on all the parts to tronics AMC board....
    went to plug it in and got no LED lights at all.
    I think i did a good job on the pcb and solidering.. although obviously there is a short or loose wire somewhere...
    I have tested that i am getting 9volts from where the power supply plugs in..
    can anyone give me hints/tips on how to debug further?
    im going to go over all the soildered points tonight. but if there is any tips on how i can try and find the problem ?
    :sos:
  2. tronicgr
    tronicgr
    Some clear photos of the top and the bottom of your board would be great, to see if there is something wrong with the parts used...
    Regards, Thanos
  3. stowaway1982
    stowaway1982 New Member
    0Coins
    Here is my board. I am going to go over all the solidered points slowly and carefully.
    I know its not the best job:
    Any assisantce would be great! The LEDS dont light up at all.
    if you can give me some advice hwo to test it with the multi-meter to find out which point or track is the problem that'd be great!
    ps- to admins. my old login wouldnt give my authoirty to view any pages on the forum.
  4. tronicgr
    tronicgr
    Measure the output pin of the LM2940 to see if it does output 5v. If not, it is faulty and needs replacement.
    Also as the LM2940-5 is a LDO parts, the perfect match power supply for it is a 6V ~1A transformer. Be sure that the transformer you used does not have center pole reverse voltage direction switch !!!!
    Regards, Thanos
  5. stowaway1982
    0Coins
    thanks alot!
    I'll have a look at that tonight
    anything else you can comment about my the board itself?
  6. tronicgr
    tronicgr
    Well, the placement of the parts looks ok, but the bottom of the board looks like its you etched the lines by yourself... Take a good magnifier and a good source of light and start searching for small short-circuit bridges...!!
    Regards, Thanos
  7. Senetor
    Senetor Member
    Australia
    595Coins
    The National Semiconductor Specs state Input voltage of 6.25 - 26 volts.
    Regards Senetor.
  8. tronicgr
    tronicgr
    Thas correct, but above 6.25v it wastes energy in the form of heat !!!! Heat makes the VCC output unstable and it will provide less amps than may required by the AMC load (for example to power the LCD backlight ...!)
    Thanos
  9. stowaway
    stowaway New Member
    1Coins
    is this what I would use a multimedia and the Continuatlity feature on it for?
    test it on each track ect to make sure there is not a short?
  10. RaceRay
    Hamburg, Germany
    23,877Coins
    I don´t understand what you want to say...
    Did you already checked the output pin of the LM2940 with a multimeter if there is 5V, and did you use proper power supply as Thanos suggest?
    regards
  11. stowaway
    stowaway New Member
    1Coins
    not yet. I am working on it with a friend at his place, so i can only do it weekends.. im goign to take all this infomraiton and put it to use on saturday.. (this is why its taken me a couple of weekends to get it together)
    I just thought that the continuatily (probably spelling it wrong) feature on the multimeter sends a signal thru the tracks and beeps if it shorts.. so i was wondering if this is what is used to test for shorts?
    However i will definetly do everythng suggested, i was just trying to get a list of things to test for the weekend when i try.
  12. RaceRay
    Hamburg, Germany
    23,877Coins
    Ah ok, i see. I know what you mean.
    I think it is better to follow every route on the pcb only with a magnifier and a spiky tool like a nail or something to follow it better.
    Should be no problem to see any short curcuits with your eyes.
    I would not to advise you to find out any short circuits only with a multimeter, because you can only measure 2 points at the same time, but there is a unlimited amount of potentialities for a shortcut between that 2 points.
    Otherwise if you got at least two defined pins and definitively know that there must be no short curcuit, than you can measure the resistance between both or more points. Any resistance near zero can be interpreted as a short curcuit i think.
    regards
    René
  13. wannabeaflyer
    wannabeaflyer Active Member
    UK - London area
    974Coins
    Hi Stowaway ( hell of a name ) went down the same road as you and have to say Tronics stuff is great and the Board does work brilliantly , as with most of us novices it will boil down to a very silly issue .. in My case it turned out to be several dry joints , a few solder bridges and even left out wire links , was pulling my hair out at one time because i knew it should work and that i must have done something wrong and guess what i did LOL:-0 the biggest smile i had for a long time was when i found each mistake and got further towards a working interface and then wow wow wow as teh Avdert Goes it does what it say on the tin to see his stuff in action madde by your own hands is brill ... so my advice get a decent magnifiying glass and check check and recheck the components placed correctly , tracks for shorts or dry joints , ID the 5Volt Rail , Jumpesr , Links and Even the crimped connectors because they are the silly things thet tripped a lot of us up ... the PCB works so its just Finger trouble as i call it .. Have fun , it will be well worth the learing curve in the end .. :cheers:
