Leadscrew lead
Discussion in 'Ready, set, go - Start your engines' started by Jerry Atrick, Apr 6, 2018.
  1. Jerry Atrick
    Sydney Australia
    1,414Coins
    4DOF
    Hi I'm going to have a a bash at a an actuator, and was wondering what would be a typical choice for the lead on a ball screw that you all are using?
    Ive seen everything from a 2 through to 10, now I know its has something to do with the speed advancing the nut but is there a calculation handy that may help me choose the right pitch.
    Regards Jerry.
  2. walxop
    walxop New Member
    39Coins
    3DOF, DC motor, SimAxe, Motion platform, 4DOF
    Thrust and motor speed and thrust are all related
  3. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,801Coins
    Speed from a screw .Make from rpm rounds second and this time screwpitch.
    3000rpm /60\=50x 5mm pitch =250mm sec
    Force in newton= 2 x pi x torque /pitch\= and this x screw efficienty
    Torque in newton
    Pitch in meter
    Screw eff. ballscrew is 90%
    hope this helps
