Showroom Building my first 2DOF (without welding or a steel frame)
Discussion in 'DIY Motion Simulator Projects' started by Brie69, Jul 3, 2018.
  1. Brie69
    Brie69 Active Member
    Beverwijk
    2Coins
    Checking whether the steering wheel will fit.... Check :thumbs
    Checking whether the cablemanagement plate still 'clicks on' the magnets.... Check :thumbs
    [tomorrow I start with the construction for the pedals]
  2. Brie69
    Beverwijk
    2Coins
    The pedals
  3. Brie69
    Beverwijk
    2Coins
    Spraypainted pedalssetconstructionthingy in place
  4. Brie69
    Beverwijk
    2Coins
  5. Brie69
    Beverwijk
    2Coins
    I'm using Lock Bond for the bolts and nuts.
  6. Brie69
    Beverwijk
    2Coins
  7. Brie69
    Beverwijk
    2Coins
    The alignment isn't quite right but the flexible couple makes it all right again.
    Everything is loose fixed for testing later on.
  8. Brie69
    Beverwijk
    2Coins
    Updated the motor mount with one extra bracket.
    I am also a bit worried about the load capacity of the engines
    151,596Coins
    +11,043 / 56 / -2
    You also need to consider the load capacity of the motor mounts, as they are subject to substantial forces, given the movement and mass of the rig. I think they need to be far more substantial than what you are using.
    They look to be wiper motors, is that correct?
    Have you tried SimCalc to get a sense of what is needed to drive your rig: https://www.xsimulator.net/communit...e-linear-speed-and-forces-of-your-design.270/
  10. Brie69
    Beverwijk
    2Coins
    That's correct they are wiper motors and no I didn't try the simcalculator yet.... All the parts that I have made till now are like 'it comes as it goes'... but the motors are a braintwister for now..
    ps. The two motors get one more mount in the same line as the motor.
    We keep I'll keep you informed @noorbeast
    151,596Coins
    +11,043 / 56 / -2
  12. Brie69
    Beverwijk
    2Coins
    The ground isolation part is done already so next thing to do is calculate the lenghts and angles of the rods/lever and start testing.
    If torque is to small then ..well ..then I have to buy stronger motors.
    Cheers @noorbeast
  13. Brie69
    Beverwijk
    2Coins
    151,596Coins
    +11,043 / 56 / -2
  15. Brie69
    Beverwijk
    2Coins
    @noorbeast thanks for the quick response.
    Yes, that was one of the first things that I have done when I started the project...
    I just measured it again but still nothing between + and housing, - and housing or between the housing of the two motors.
    Cheers
  16. noorbeast
    151,596Coins
    +11,043 / 56 / -2
  17. Brie69
    Beverwijk
    2Coins
  18. Brie69
    Beverwijk
    2Coins
    What is wrong? I've uploaded the @RacingMat _2DOF_Arduino_code with a USB cable to the Arduino...installed SimTools latested version..downloaded/installed/patched some gameplugins..
    The settings in the Game Engine are those correctly filled in?
    When I start, for example Dirt Rally, the motors give one 'kick' when starting the game but when I start driving the motors stay still.
    If there is anyone how can help me with this is much appreciated.
    151,596Coins
    +11,043 / 56 / -2
    For SimTools 2 the Interface Output should be: [A<Axis1a>][B<Axis2a>][C<Axis1a>]
  20. Brie69
    Beverwijk
    2Coins
    Sorry, @noorbeast but even when I set the Interface - Output like you said [A<Axis1a>][B<Axis2a>][C<Axis1a>] still no movement.
    Do I need to change the Arduino code or something?
    The Arduino is connected via USB A <> USB B cable to the pc
