Dampers Kit
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by patatrac, Jun 7, 2009.
  1. patatrac
    patatrac New Member
    My simulator and my family.
    318Coins
    Hello everybody,
    I have praticaly finished my simulator, but i have a question concerning the dampers.
    In fact i saw this type of dumper kit:
    And i was wondering if this could be good?
    I should go with the first dampers or the second?
    Thanks for your response?
  2. FAG
    FAG New Member
    Perm/Russia
    413Coins
    I want build following scheme:
  3. RaceRay
    Hamburg, Germany
    23,892Coins
    The second one will not damp anything.
    The pole inside the rubber damper must be movable and the ends of the damper must push against the holding brackets.
    Not easy to explain for me in english, but try to understand the functionality and difference between both.
    That picture should helps a lot:
    [img600px]http://www.x-simulator.de/forum/download/file.php?id=2075&mode=view/Daempfer_Aktuatorenarm_egoexpress.GIF[/img600px]
    Edit: thread moved into proper one
