News SimTools v2.3 is out!
Discussion in 'News' started by yobuddy, Sep 26, 2018.
  1. yobuddy
    51,005Coins
    Here is what you need to know:
    GameDash v2.2 & GameVibe Beta4 both require SimTools v2.3 and above.
    If you are running an older version of SimTools, when you update SimTools, also update GameDash and GameVibe.
    Smoothing weight has been doubled mainly for our high flying friends.
    To get the exact same profiles as you had before, simply adjust your profiles as follows.
    Axis Assignment Smoothing: (Example: if at 20%, slide down to 10%)
    For Main Level % in Game Manger: (Example: if at 50%, slide up to 75%)
    That's all that is needed for SimTools v2.3
    If you don't have it yet, a bran new manual can be found here!
    https://www.xsimulator.net/community/threads/official-simtools-user-manual.12424/
    It fully covers all the new features of SimTools v2.3.
    For those of you with rotation lever type motors, be sure to check out the new Advance Axis Assignment plugin with its new Linear to Rotation output filter.
    The filter has the ability to make the ride buttery smooth ;)
    Have Fun! :thumbs
    • Like Like x 7
  2. AussieSim
    AussieSim Member
    Australia
    1,452Coins
    First post !
    Thanks, yobuddy, downloading now.
    Just to clarify, the "main level" is about smoothing and not strength ?
    Do I need to backup my profile/settings prior to update ?
  3. SeatTime
    Windows says no..... - maybe windows security needs an image update.
  4. yobuddy
    51,005Coins
    The Main Level % applies smoothing to All of the data coming from the game. (its how it adjusts the strength if you will)
    When this value is at 100 %, it uses no smoothing at all, and you are riding the direct data supplied from the game.
    As you lower the Main Level % value you are applying smoothing to all inputs from the game plugin.
    You should not need to, other than simply adjusting the profiles as i have show above.
    You should be able to simply install SimTools v2.3 over your existing installation of SimTools.
    I tested it quite a few times without any problems.
    But, please make a backup and give it a go.
    Seems you are the first to give it a try.
    Let me know how it goes for you.
    Take care!
  5. yobuddy
    51,005Coins
    @SeatTime
    Problems buddy?
    Its always something with windows lol
    Chat soon,
  6. AussieSim
    AussieSim Member
    Australia
    1,452Coins
    upgrade went smoothly, no problems.
    Windows 10 Pro v1803 build 17134.228
  7. yobuddy
    51,005Coins
  8. RCFlyer
    RCFlyer Member
    139Coins
    Where do I find the new Advance Axis Assignment plugin? I looked in the simtools plugin section and didn't see it.
    Danny
  9. yobuddy
    51,005Coins
    @RCFlyer,
    It's Under the axis assignments in Game Engine.
    Take care,
  10. RCFlyer
    RCFlyer Member
    139Coins
    Thanks.
    Question on the roll-over item. Does this apply to doing loops or barrel rolls in aircraft. I believe we use sway before.
    Danny
  11. PIM1
    PIM1 VR Racer
    Fitness Instructor
    United Kingdom
    150Coins
    2DOF, SCN6, Motion platform
    Where is the link to download ? I have downloaded game vibe beta 4 but can't find simtools download tab . Thanks
  12. yobuddy
    51,005Coins
  13. yobuddy
    51,005Coins
    Yes, it makes it so it does not jump from one side to the other when doing loops.
    Anti RollOver – This setting returns the output value to zero when the input is at its max or min setting. For Instance, if we had a Max and a Min of 180°/-180° for an input and this setting was on, any values after 90° start counting back to zero. Making an input of 100° = 80°, 120° = 60°, and 180° = 0°. The same thing happens for the negative values also meaning that a -180° = 0°. (Note: This setting is only intended for the Roll and Pitch inputs from a game.)
    Take care,
  14. PIM1
    PIM1 VR Racer
    Fitness Instructor
    United Kingdom
    150Coins
  15. Leandro Kemp
    Brasil
    - 10Coins
    Hello. Where do I set these values? Thank you.
  16. yobuddy
    51,005Coins
    Anti RollOver is a filter available in the Advanced Axis Assignments plugin.
    Take care,
  17. Leandro Kemp
    Brasil
    - 10Coins
    I'm find. Tankyou
  18. 김민혁
    김민혁 Member
    - 5Coins
    Thank you for developing a good program. But it doesn't work perfectly in the language I'm using. I hope it improves in the next version! Thank you for your hard work
