Question float suspensionTravel & float cgHeight instead of float cgHeight only
Discussion in 'Off Topic - All other stuff here' started by Pit, Sep 29, 2018.
  1. Pit
    30,490Coins
    Also a question for our devs @value1 and @yobuddy . While "heave" allows only "one" DOF we know that a car has 4 ends and 4 wheels (mostly). That said "heave" is not only lifting the car from a central point, it is a very complex up and down. An important role plays the chassis and the suspension travel. As we know in a game like Assetto Corsa the suspension travel data is available for all 4 suspensions which allows me to ascertain that heave is limited and should be only one component in our calculation model. If I have a 4DOF at minimum I could reproduce all these suspension effects which should result in a better heave experience of the road texture.
    Developing plugins in that direction would be a big step forward. Any comments are very welcome :)
  2. yobuddy
    51,005Coins
    You mean like a 4corner sim like a Dbox?
    If so, heave would still have to do the same on all legs, or the legs would just be kicking all over the place as they are out of sync.
    The way I see it, the chassis of the car is the feeling the diver is experiencing.
    So I think using the suspension travel data would be like having a seat on top of the suspension.
    Anyway, just some thoughts.
    Take care,
  3. Pit
    30,490Coins
    Thank you buddy for your thoughts which confirms that I was not clear with my question. Do you mean that Roll and Pitch combined with heave is all we need? I know that the suspension travel is not to be meant to be reproduced 1:1 on the rig, instead of this the position of the suspension in relation to the car's height position.
  4. yobuddy
    51,005Coins
    I believe what we want is just heave relative to the car.
    I'm sure we could probably put something in a plugin to use the suspension travel to maybe enhance some road detail effect, but really the data should already be in the heave stream we already have. At least as it relates to the chassis of the car.
    I would probably go the route of lowing my heave max mins values a bit to see what i could pic up, but you have probably done that already.
    Take care @Pit :thumbs
  5. Pit
    30,490Coins
    yes...as lower the min max settings are, as more details I can feel coming from the road texture but as a consequence of that I have to use smoothing and boundary filter. This is all fine. What I miss a little bit is the chassis behavior, or better said the elevation from the chassis caused by the wheels rolling over curbs and bumbs.
    EDIT: Roll can also simulate this, but needs a lot of experience and compromises.
  6. value1
    15,026Coins
    Hi Pit
    The four suspensions move up and down independently, indeed.
    The four movements result in one single movement of the car seat.
    Depending on the accuracy of the physics model of the simulation, the four independent movements of the suspension will also result in one single heave as output in the simulation's heave data stream.
    You can now argue the accuracy of the physics model of various simulations and if suspension travel more accurately describes the feelings of the driver than the heave value. But for that we would need to study the exact physics model of the car and how it calculates the various output values. (e. g. "heave" might be calculated for the center of gravity rather than the driver)
  7. SeatTime
    Agree and dependent on the Sims design you would also have to be careful in how you then use that data to drive your rig.
