Question 6 dof mini servo build
Discussion in 'DIY Motion Simulator Projects' started by waldo wautelet, Aug 24, 2018.
  1. waldo wautelet
    waldo wautelet You found me...
    Belgium herent
    165Coins
    Hi, I am for the moment working on a little project with an arduino uno and 6 servo's , but I am stuck for the moment on how I have to assign my axis, I dont know wich percentage I should use or what servo should turn more then the other. Someone who can help me with that?
  2. waldo wautelet
    Belgium herent
    165Coins
    Well i Found how i have toch do my Axis assignment but forum thé moment i'm stuck with another problem, when i give nothing from output for my simulator it moves without me wanting to...
  3. waldo wautelet
    Belgium herent
    165Coins
    I forgot to upload the video file. Sorry
    https://photos.app.goo.gl/4qoJnxRFfYCC4ooc7
    153,758Coins
    +11,149 / 57 / -2
    Can you please post pictures of all of your settings, in particular your Interface Settings, Axis Assignments and Tuning Center settings.
  5. waldo wautelet
    Belgium herent
    165Coins
    Here are the pictures of the Interface Settings, Axis Assignments and Tuning Center settings. These screenshots where taken while the simulator was moving with no output.
    153,758Coins
    +11,149 / 57 / -2
    I am presuming you altered @eaorobbie's code to match the A B C D Interface output, so try changing the Output Rate to 10ms.
  7. waldo wautelet
    Belgium herent
    165Coins
    Well I tried this out and I still got the same result.
  8. MarkusB
    4,215Coins
    I once had the same issue, and the reason was that the power supply for the servos was not strong enough.
    I assume that these black and black/white cables in the picture below belong to the power supply for the servos, right? So does it have enough power to supply the 6 servos?
    And did you connect all GND cables (servos and external power supply) to the Arduino's GND pin?
  9. waldo wautelet
    Belgium herent
    165Coins
    Yes, I did, thé Powerpoint supply is rates at 6volts 3A so it should be strong enough and yes I connecties all my GND'S with the Arduino.
  10. MarkusB
    4,215Coins
    Just to be sure, you could try to unplug all servos except one and check if this one still moves. Then check with two servos and so on.
  11. waldo wautelet
    Belgium herent
    165Coins
    Ik I Will try!
  12. waldo wautelet
    Belgium herent
    165Coins
    I tried it out and yeah from the moment I connect 6 servo's it does this weird thing but what I noticed is this one, if I type in (manually) this first line in the first picture then it adds a 0 to the last servo's value... I think that this can be one of the problems...
  13. waldo wautelet
    Belgium herent
    165Coins
    Uptade!
    Itried a lot off things out and what I was wondering about was that is was really weird in my sketch for my Arduino, There was a line that I could not understand and I just deleted it and that solved the problem of the extra 0 that comes and goes. Something that I noticed while testing, the servo's that are moving so weird are not even getting a signal from the Arduino, I disconnected them and it still stays, someone knows what I have to do now? because I think when there is no PWM signal send to a servo it moves so weird just the same as it moves when I disconnect them. Please can someone help me?
  14. waldo wautelet
    Belgium herent
    165Coins
    UPDATE!!
    I fixed it with deleting that one line, it said that if the value was under 0 or above 9 it can not do anything and that fixed everything, now it works. Next problem, the servo's move to little to really feal it in the small simulator so if anyone can explain how I can make it so it moves more then I would really appreceate that! Thanks alot!
