Bug game vibe crash on start
Discussion in 'SimTools Pro & Entertainment Version' started by stargazer, Sep 27, 2018.
  1. stargazer
    stargazer Active Member
    Electrical/Computer Engineer
    Boston,USA
    811Coins
    3DOF, Arduino, Motion platform, 4DOF
    Hi
    I would like to run game vibe to control a buttkicker. But every time it would crash right at the start with the message:
    "System.InvalidOperationException: An error occurred creating the form. See Exception.InnerException for details. The error is: Could not load file or assembly 'Microsoft.DirectX.DirectSound, Version=1.0.2902.0, Culture=neutral, "
    would you know how to fix this error?
    My system is a win10 64 bit, i7-7700k cpu @4.2Ghz, 16GB
    thank you,
    error message details:
    System.InvalidOperationException: An error occurred creating the form. See Exception.InnerException for details. The error is: Could not load file or assembly 'Microsoft.DirectX.DirectSound, Version=1.0.2902.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies. The system cannot find the file specified. ---> System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.DirectX.DirectSound, Version=1.0.2902.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies. The system cannot find the file specified.
    at GameVibe.frm_SoundCardSettings..ctor()
    --- End of inner exception stack trace ---
    at GameVibe.My.MyProject.MyForms.Create__Instance__[T](T Instance)
    at GameVibe.frm_GameVibe.frm_GameVibe_Load(Object sender, EventArgs e)
    at System.EventHandler.Invoke(Object sender, EventArgs e)
    at System.Windows.Forms.Form.OnLoad(EventArgs e)
    at System.Windows.Forms.Form.OnCreateControl()
    at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
    at System.Windows.Forms.Control.CreateControl()
    at System.Windows.Forms.Control.WmShowWindow(Message& m)
    at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
    at System.Windows.Forms.Form.WmShowWindow(Message& m)
    at System.Windows.Forms.Form.WndProc(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
    mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.7.3163.0 built by: NET472REL1LAST_C
    GameVibe
    Assembly Version: 0.1.6.0
    Win32 Version: 0.1.6.0
    CodeBase: file:///C:/Program%20Files%20(x86)/GameVibe/GameVibe.exe
    Microsoft.VisualBasic
    Assembly Version: 10.0.0.0
    Win32 Version: 14.7.3056.0 built by: NET472REL1
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    System
    Win32 Version: 4.7.3151.0 built by: NET472REL1LAST_B
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Core
    Win32 Version: 4.7.3160.0 built by: NET472REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    Win32 Version: 4.7.3056.0 built by: NET472REL1
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Configuration
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Xml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    System.Runtime.Remoting
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
    GameVibe_PluginAPI
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/GameVibe/GameVibe_PluginAPI.DLL
    XAudio2_GameVibePlugin
    CodeBase: file:///C:/Users/nguye/AppData/Local/GameVibe/AudioPlugins/XAudio2_GameVibePlugin.dll
    enabled.
    For example:
    <configuration>
    </configuration>
  2. stargazer
    Boston,USA
    811Coins
    I did a bit of googling and managed to install directx sdk. then I got a new error message about just intime debugger (JIT).
    mscorlib
    GameVibe
    System
    System.Core
    System.Drawing
    System.Xml
    GameVibe_PluginAPI
    enabled.
    For example:
    <configuration>
    </configuration>
  3. yobuddy
    51,518Coins
  4. stargazer
    Boston,USA
    811Coins
    that fixed it @yobuddy. I just got it working and the experience is beautiful. thank you.
