News New higher Voltage / Amperage JRK's!!!
Discussion in 'Ready, set, go - Start your engines' started by Brett Horton, Apr 20, 2018.
  1. CQeNS
    CQeNS New Member
    50Coins
    Hey Marco can't really help with your question.
    Here is how I went about mounting my G2s, i think cooling wise its a complete overkill for those units, but I had most of the things left over from the returned 12v12 so I didn't have to purchase anything
  2. MarcoMade
    MarcoMade Active Member
    italy
    157Coins
    ok sorry maybe I explained myself bad, I wondered why you use these drivers more expensive than the bt2s 43 A, what were the advantages since they cost more. just this thanks hello, anyway you did a nice job very clean and professional;)
  3. CQeNS
    CQeNS New Member
    50Coins
    I don't know if there are really any advantages compered to other units out there. I wanted to keep things as simple as possible for my first build. Easy to install, easy to configure, less things to go wrong. I did not have any experience with configuring a controller boards before, and having to use code just made it a bit more complicated. JRKs offered proven unit that has worked well with PGsaw 180W motors, and was already integrated well into Simtools.
    I think it makes sense to pair your board to your motors, and maybe for my next project I will use something else, it worked well with this project.
  4. MarcoMade
    italy
    157Coins
    OK perfect!! now we understand each other;) and only a practical question.
    Thanks for your patience
  5. Nick Moxley
    How i mounted/Wired up a set for a buddy
  6. MarcoMade
    italy
    157Coins
    very neat, they are really small and well built to see, I like 3DPrinted support, you used PLA or PETG.
  7. Nick Moxley
    I used PLA, No need for PETG, you can flex on the little mounts all day long and they wont break due to the print axis.
  8. Smbat Meliksetyan
    Smbat Meliksetyan New Member
    44Coins
    153,703Coins
