SilentChill
EliteDangerous Horizons Plugin (OLD Archive Thread) Version 3.3.0.2
EliteDangerous Horizons Plugin (VR Version)
Thread Status:
Not open for further replies.
  1. polybasss
    polybasss Member Gold Contributor
    Burgos Spain
    155Coins
    Ohh, I've seen the GetBaseAddress64.dll if I have it so that's not the problem
  2. Mechromancer
    434Coins
    Did those axes work for you before on ED? I know you said you just downloaded the plug, but I'm not sure if you just now downloaded the latest or this is the first time you use it.
    The DIR on SWAY and SURGE are reversed on my set-up. For me it's SWAY: DIR, DIR and SURGE: NO DIR, DIR.
    Also, you may have a custom rig, but for the DOF Reality the Axis go in this order:
    Roll, Pitch, Sway, Surge, Heave.
    The reason I mention all this is because the exact same thing happened to me when I first download this plugin. The rig dove right and wouldn't move when the game started.
    Also, as noorbeast pointed out, make sure you have the latest Offset file.
  3. polybasss
    Burgos Spain
    155Coins
    is the first time I use it and download the latest version, the platform in effect, it is personalized, and it is possible that it was inverted, trying a plugin with dirt rally when braking got up and changing the DIR already works correctly.
    I will prove that.
    Thank you
  4. splendiddd
    splendiddd Active Member
    CCTV security
    Netherlands
    812Coins
    Ok after just doing a fresh windows 10 install, i can conform THAT IT NOW WORKS!!!!!
    I am soo happy now.
    Thanks guys for all the support!
  5. Mechromancer
    434Coins
    :cheersAWESOME!!!!
    What a great feeling, huh?!
  6. splendiddd
    CCTV security
    Netherlands
    812Coins
    Yes! however i wish i could reduce the jerkeyness when the platform goes to neutral stand, i mean when i let go of the joystick, its really too jerky.
    Yes i did try smoothing and did create proper profile myself(on other games this works great) and also with tuning center,amount of axis use etc.
    Only thing i dont understand is the release and gain sliders in the filter section? maybe that would do the trick?
    Or is this just the way it behaves for most users?
  7. Mechromancer
    434Coins
    153,001Coins
    +11,116 / 56 / -2
  9. yobuddy
    51,358Coins
    153,001Coins
    +11,116 / 56 / -2
    Sorry copied it incorrectly, fixed now.
  11. traveltrousers
    traveltrousers Active Member
    Timbuktu, Tombouctou, Mali
    890Coins
    Good news, the pointer layout looks the same for the 3.3 Beta.... should be quick to update...
  12. polybasss
    Burgos Spain
    155Coins
    I love this game and with this plugin it's a wonder, the bad thing is that the movement is broken when approaching planetary bases or when landing on planets, restarting the game is solved and every time I remove the game I get an error message
  13. Trip Rodriguez
    Trip Rodriguez VR Pilot
    Lake Ariel, Pennsylvania
    3,977Coins
    I hope you are right @traveltrousers and that @SilentChill has an easy job this coming week with the update!
    I came here to tell everyone it's time to start telling him how amazing he is and showering him with compliments. =)
    I'm also planning to play a lot of CQC (Arena) in the coming weeks, so hopefully we don't have any problems making motion work in that as well after the patch.
    Trip
    PS- I know there are others who have put in significant time and effort here as well and I don't mean to ignore you guys, but I'm pretty sure SilentChill has put in way more time and effort creating and maintaining SimTools plugins than anyone else.
  14. Benji85
    Benji85 Member Gold Contributor
    851Coins
    Here's hoping it's easy! I've actually been without motion for 3 weeks (savage) had a Arduino board go on my dof reality h2. Tried twice to fix it with flash and soldering etc but no. £200 to get new control box shipped but it's in the way and I'm excited to get back in the chair.
  15. onhill
    onhill New Member
    - 18Coins
    hi iam getting the wow64 dll message i cant install the plugin what can i do ?
  16. onhill
    onhill New Member
    - 18Coins
    solved i started gamemanager as admin thx
  17. onhill
    onhill New Member
    - 18Coins
    ok looks like there is another problem
    i cant set up the axis looks like there is no motion signal coming out of the game... i have no valves in the tuning center but simtools is connected
  18. kev b
    kev b Active Member
    Academic Lecturer - Electrical Engineering
    Swindon, UK
    929Coins
    3DOF, Arduino, Motion platform, 6DOF
    gotta agree Trip.... I've had a great blast in my 6dof rig since the last big ED update. Gotta thank all the guru's for the pointer xml files.
    I play ED a lot and had all 6dof work well in main game and in all situations except when changing ship at which point heave and surge went random. Reboot ED and all was fine again.
    Never got all 6 to work in CQC tho (heave and surge went random after a few mins in game, every time, so I disabled those 2 axis when playing CQC). Tried and swapped about the different pointers found by others but to no avail.
    Gonna be on joystick mode for a bit now until the guru's work their charms after the ED update dust settles. Will we still be able to just up-date the xml rather then a full plugin install?
    Kev
  19. Pauljg79
    Pauljg79 New Member Gold Contributor
    Technical sales manager
    Oxford
    102Coins
    I'm getting the same problem, I've got a DOF Reality P3 - No game data at all from elite, patched and connected fine. It's very strange. Any tips on this problem would be much appreciated!
  20. onhill
    onhill New Member
    - 18Coins
    Yes that's strange all my other games are working fine. :( I hope too there is some hero out who can fix this little problem.
Thread Status:
