Showroom My 6DOF with DIY Actuators
Discussion in 'DIY Motion Simulator Projects' started by Vitalius, Sep 1, 2018.
  1. Vitalius
    Vitalius Active Member Gold Contributor
    Bonn
    538Coins
    Motion platform, 6DOF
    Hello everybody!
    I plan to build a 6DoF and try enall hardware like here pmvcda forum: https://www.xsimulator.net/community/threads/flypt-6dof-brushless-diy-actuators.10799/
    or here from SixDegreesOfFlight: https://www.xsimulator.net/community/threads/x-plane-11-6dof-motion-platform.10542/
    shopping.
    Unfortunately, I could not find an electric motor in Germany with the same characteristics as https://www.motiondynamics.com.au/my9764-450w-24v-dc-motor.html .
    I have decided for this engine: Link
    What do you think about that? Is that too slow?
  2. Grigory
    Grigory Active Member Gold Contributor
    Moscow
    221Coins
    3DOF, 6DOF
    Do you plan to make linear actuators?
    Depending on the weight of your moving platform you may try ballscrews with greater pitch to increase linear speed.
    My first 6dof used 3000rpm 1.57 Nm motors with 5mm screw pitch. The cockpit was all steel and very heavy, but the actuators proved quite capable to move it sufficiently fast. I think I could well use 10 mm pitch back then. With my current light aluminum cockpit, I believe, the same motors could manage even greater pitch.
    • Old Old x 1
  3. Vitalius
    Bonn
    538Coins
    Yes I'm planning linear actuators.
    I ordered a SFU1605 500mm. Here.
    But this has 5mm thread pitch. I hope this is enough.
  4. Vitalius
    Bonn
    538Coins
    Hello everyone, I have almost finished work on the first actuator. there are only little things left.
  5. Zwodog
    Zwodog New Member
    Austria
    65Coins
    Motion platform
    Hi. Nice work in that actuator. May I ask how you build the parts. 3D Printing? Do you follow a former build from the Forum, or did you redesign any parts. What Controller so you plan to use. I follow this forum for some years, but still collecting information. Looking forward to follow your build.
  6. Vitalius
    Bonn
    538Coins
    Hello Zwodog, all parts were created with 3D printer.
    Many parts i have taken over in forum and adjusted for me and rebuild.
    I plan to use a Sabertooth dual 60A motor driver with Arduino.
  7. Vitalius
    Bonn
    538Coins
    I have selected MY7618 24V 300W Rated current 16 A 28000RPM motor. I bought a power supply 24V-40A on eBay. Now you need one
    SKN Stud Diode.
    Now have questions for you:
    Is it enough for a SKN 70/16 diode from state SKN100 / 18?
    Here I have a link where I can buy the diode.
    All diodes in overview.
    Price difference is really big between SKN100 / 18 (100A) and SKN70 / 16 (70A).
    Do I need two Stud diodes per power supply?
    So you have to use plus and minus leads from power supply with it safe or just plus lead?
    Thank you for your help!
  8. Gadget999
    12,007Coins
    is there a video of the actuator working ?
  9. Vitalius
    Bonn
    538Coins
    not yet, I'm waiting for Sabertooth motor driver.
  10. Vitalius
    Bonn
    538Coins
    Have found out here in forum which diodes I can use. Here is del link in forum and to the diode. But still have questions about it:
    Are not the blocking diodes a bit over-immersed? I also need some and am thinking of me to get a little smaller. I use a 24V 40Amper power supply a MY7618 engine 300W 24V 16A and sabertooth 2x60 motor driver. Reich might have a diode with 80A or even 50A and 400V?
  11. Vitalius
    Bonn
    538Coins
    Hello everybody! I need your help.
    I have built a test circuit of power supply 24V 40A, Sabertooth 2x60 and Arduino Mega.
    Everything without motors!
    Unfortunately, it looks like power supply is defective or too weak. Power adapter makes click and hiss noises.
    So it sounds like something in the power supply is constantly bursting but just quietly.
    Do you have an idea what is going wrong here?
    Thank you in advance!
  12. Vitalius
    Bonn
    538Coins
    I think mistakes are found. It looks like the power supply is defective.
  13. Gadget999
    12,007Coins
    adjust the small screw next to the green led - you may be able to get more volts
    if you need to test the actuator - use a car battery for now
  14. Vitalius
    Bonn
    538Coins
    You mean little potentiometer. Have already thought of it. The problem is that the 24 V 40A power supply is on for a short while and again you can see it from the blinking LED on the board on the right. Have power pack packed again and wait for the return confirmation from Ebay seller.
    Have a 24V 15A power supply. connected. Jetz. everything works. For now, enough for testing.
  15. Vitalius
    Bonn
    538Coins
    I will connect the battery soon. I'm waiting for battery disconnect switch and a relay. Then I can test my actuator.
  16. Vitalius
    Bonn
    538Coins
    Hello everybody!
    The tutorial SMC3-PLC Sabertooth Packet Serial PID motor driver w / SoftStart is very helpful but unfortunately does not describe where the limit switches are connected.
    Are limit switches supported in SMC3_packet_serial_beta8_softstart.ino source code or do I need to change what source code?
    Does anyone know a thread here in forum which can help me? I also searched for it here, unfortunately without success :-( .
  17. Gadget999
    12,007Coins
    a dell a930 power supply from a server can be bought cheap and will supply 930w !
  18. BlazinH
    16,664Coins
    Limit switches are not supported. Since absolute position sensors are used they are not necessary except as a backup safety device. When used strictly for this purpose it's best to have the switches directly cut power to the motors anyway.
  19. Vitalius
    Bonn
    538Coins
    Hallo Gadget 999, danke für den Tipp. Diese Netzteile sind bei Ebay als Gebrauchtware wirklich billig. Kannst du mir hier einen Thread im Forum empfehlen, wo Dell-Netzteile behandelt werden? Ich nehme an, ich brauche zwei davon 12V x 2 = 24V in Reihe oder?
  20. Vitalius
    Bonn
    538Coins
    Hello BlazinH, thanks for the quick reply!
    I have also found something on this topic here in forum. Will try with relays as was done in thread of sixdegreesofflight.
