LFS not outputing data
Discussion in 'LFS - Live For Speed' started by HAOTIAN SU, Oct 22, 2018.
  1. HAOTIAN SU
    HAOTIAN SU New Member
    3Coins
    I am testing the output from LFS with simtools 2.3 demo.
    With the following setup, the game manager can show connected information but there is no output in the tunning center. Please help.
    axis assignment
  2. HAOTIAN SU
    3Coins
    the axis assignments might be unclear
  3. HAOTIAN SU
    3Coins
    the LFS version is 0.6T
    @yobuddy I wanted to test the Video Ride Recorder with LFS but found even more problem. LFS used to work fine with default setup (output is normal in tuning center) but now it can't work. The simtools I was using is a newly installed version 2.3. But the LFS wouldn't work on another computer with PRO licensed v2.2.5
  4. yobuddy
    51,535Coins
    Un-patch LFS.
    Then launch the game and complete a race.
    Exit the game and re-patch it.
    Out of all of the games, I know LFS works, I use it for testing all the time.
    Take care,
  5. HAOTIAN SU
    3Coins
    Thank you @yobuddy This works! The video recorder is working fine but cannot capture data. I will detail the issue in the other thread under video ride recorder.
  6. yobuddy
    51,535Coins
  7. Rodrigo Franca
    Rodrigo Franca New Member Gold Contributor
    Brasil
    142Coins
    Hi. Were you able to get your system to communicate with the game? I have the same problem, the engines work in the output testing mode, but when the game works there is no communication and the engines are stopped.
    153,866Coins
    +11,154 / 57 / -2
  9. Rodrigo Franca
    Brasil
    142Coins
    Oi Vr Noorbeast, como você está? Joguei um pouco, mas talvez não o suficiente. Fiz mais algumas voltas com carros diferentes e na nova tentativa o sistema funcionou.
    153,866Coins
    +11,154 / 57 / -2
  11. susocalfail39
    susocalfail39 Member
    GALICIA, ESPAÑA.
    50Coins
    That happened to me a long time ago and I also asked, you have to run a few laps before patching with simtools and capturing movement with a tuning center.
    I use traslator.
  12. pfm21
    pfm21 pfm21 build 3dof dinamic
    374Coins
    so if i understand i have to play a little bit before pacing the game and then patching and reading the values?
  13. noorbeast
    153,866Coins
    +11,154 / 57 / -2
  14. pfm21
    374Coins
    153,866Coins
    +11,154 / 57 / -2
    Could you please explain a bit more, as I don't know what you mean.
  16. Jodino
    Jodino New Member
    The Netherlands
    99Coins
    do I need to shutdown the game after a 1 round race? Or stop the game to start screen?
  17. yobuddy
    51,535Coins
    Not sure if your using version 2 or 3 of SimTools, but this should help.
    Un-patch LFS in v2 - or remove the plugin from v3.
    Then launch the game and complete a race in cockpit view. (press 'v' on the keyboard to get into the cockpit view)
    Exit the game and re-patch it or reinstall the plugin and you should be golden.
    (be sure to setup a motion interface plugin, or simtools may think it does not need to do anything)
    Buzz me if you have any problems.
    Take care,
  18. Jodino
    Jodino New Member
    The Netherlands
    99Coins
    yes!
    i just closed everything. opened, raced and shut down LFS. then opend the simtools (2) patched it again and it worked! I can go to the next step...
    Thanks!
