ACTC GAME PLUGIN
Discussion in 'rFactor' started by ne02005, Oct 23, 2018.
  1. ne02005
    ne02005 Member
    Argentina
    105Coins
    Hello I´m looking for ACTC game plugin (based on rfactor)
    tHANKS
    152,355Coins
    +11,075 / 56 / -2
  3. yobuddy
    51,098Coins
    ACTC is based on rFactor 1 or 2?
    What is the exe process associated with the game?
    (please look in task manager)
    It could be all that is needed is a new exe entry to make this one work.
    take care,
  4. ne02005
    ne02005 Member
    Argentina
    105Coins
    The game is based on rfactor. Is a refactor moded.
  5. moaale
    moaale IAN MRTIN
    NN
    ARGENTINA
    96Coins
    2DOF, DC motor, SimforceGT
    Hello friend, I am from Argentina. Notice that a while ago I wrote my own ACTC and RFACTOR tutorial.
    MOAALE ACTC SIMTOOLS SOLUTION
    01 first install the rfactor the most basic usually wherever you want.
    02 second install the actc with all its updates normally.
    03 third make a backup of all the files except the folders in the directory of C / Road tourism simulator .... where you installed the ACTC
    04 fourth change the name of the actc autorum called LoaderTC.exe to rFactor.
    05 fifth patch the Simtools - game Manager and look for the actc autorum renamed to rfactor.
    06 sixth copy the LoaderTC.exe file from where you created the backup of all loose ACTC files and paste it where you renamed the previous LoaderTC.exe to rfactor.
    and finally to play with the simtools normally, first you open the rFactor icon with a double click to activate the game manager in blue as it normally does and second you open the LoaderTC icon
    to play normally at actc 2020.
