Codemasters Dirt Rally Plugin 2.0.0.3
SimTools plugin for Codemasters Dirt Rally
  1. yobuddy
    51,560Coins
    Turns out the trigger is already in this plugin. 2.0.0.3. :thumbs
    Although, there is another rally plugin floating around that does not support the oculus version of the game.
    And that is what the problem was here.
    Take care all,
  2. BlazinH
    16,691Coins
    Imo if would be good if valid .exe triggers are stated on the plugin's page too so people are aware ahead of time if their version works or not. It would save their time and ours. They would also know for sure which version to purchase if they haven't bought it yet.
  3. yobuddy
    51,560Coins
    All game triggers are listed on this page.
    If the plugin has multiple triggers, it will flip thru them all.
    Take care!
  4. yobuddy
    51,560Coins
    Sure!
    All SimTools v2 versions will.
    But I would still suggest updating SimTools thou.
    As the big reason for updates is to correct errors and make things work better.
    Take care,
  5. Majony
    Majony Member
    54Coins
    SCN6, 4DOF
    153,986Coins
    +11,162 / 57 / -2
    The download for the plugin is here: https://www.xsimulator.net/community/marketplace/codemasters-dirt-rally-plugin.140/
    You either buy access to plugins or use 250 forum activity coins for a weeks access to all plugin downloads:https://www.xsimulator.net/community/faq/coins-and-how-to-download-plugins.2/
    If you use a 64 bit system then the patch path is: C:\Users\Your_User_Name\Documents\My Games\DiRT Rally
    See here fo the steps to create and refine a motion profile, doing one axis at a time: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  7. Majony
    Majony Member
    54Coins
    SCN6, 4DOF
    Thanks @noorbeast, buy i have the last Dirt Rally pluggin and nothing about sway and surge, i thought that file refers to some kind of patch to fix that.
    A lot of people do, but nobody has been able to solve it, right?
  8. Majony
    Majony Member
    54Coins
    SCN6, 4DOF
    Hi people, testing the game this afternoon, I've seen that the sway and surge they work in some sections, I've seen it work in two of Germany specifically, always in the same, it's strange that's true?
  9. Kranky Pantz
    Kranky Pantz Active Member
    Canada, Eh!
    1,288Coins
    If someone were to have both the Steam & Oculus versions of DiRT Rally installed on the same PC, does patching it for motion automatically do both versions?
    Or is it a one or the other type of thing?
    If that's the case, then how would we be able to choose which one to patch?
    Unless of course the game settings for both versions happens to be in the same file location by default, like perhaps the "Users" folder in Windows 10.
  10. yobuddy
    51,560Coins
    I expect that for a 64bit machine they would patch in the same place in documents/games/hardwareconfig.
    And for 32 bit versions they would get patched in there installation folders.
    I would expect them to all work fine, but I only have the steam version to test with.
    The sway and surge problem of this title can be fixed buy changing the resolution and then changing it back once in full screen mode. This problem seems to be caused by Alt-Tabin out of the game while it is running. (although, I personally have not had this problem)
    Take care!
  11. Kranky Pantz
    Canada, Eh!
    1,288Coins
    Thanks for the reply.
    With so many game launchers/clients these days, I was curious if two different versions of the same game would work.
    Unfortunately I missed the Oculus sale on DiRT Rally, otherwise I would have tested it myself.
    Supposedly the Oculus Store version may run a bit better for Rift users than the Steam version does.
    Lately I've been finding the Steam version almost unplayable in VR...just ugly and with low frame-rates.
    Perhaps I'm just spoiled by how great the pCARS 2 Rallycross events both look and perform, but of course that's a different game engine.
  12. cover4x4
    cover4x4 I love simracing
    Car Mechanic
    Spain
    68Coins
    2DOF, SCN5
    Hi, I have a problem with the Dirt Rally plugin. I have this game on Steam and I do not get it in the fold-out games in Simtools. With the other games I have not had problems to install since they do come out in the dropdown of Simtools and I can put the path, but Dirt Rally does not, so I can not install the path. Any suggestions? The state is looking at the forum, but my English is not very good ... Regards.
    Hola, tengo un problema con el plugin de Dirt Rally. Este juego lo tengo en Steam y no me sale en el desplegable de juegos en Simtools. Con los demás juegos no he tenido problemas para instalar ya que sí salen en el desplegable de Simtools y puedo poner el path, pero Dirt Rally no, con lo que no puedo instalar el path. ¿Alguna sugerencia? El estado está mirando el foro, pero mi inglés no es muy bueno ... Un saludo.
  13. noorbeast
    153,986Coins
    +11,162 / 57 / -2
    What version number of SimTools are you using?
  14. cover4x4
    Car Mechanic
    Spain
    68Coins
    2DOF, SCN5
    Thank you very much, I will read the links that you have put me and I will continue informing. A greeting.
    Muchas gracias, leeré los enlaces que me has puesto y seguiré informando. Un saludo.
    The version of Simtools is 2.2. These days I'm a bit involved with work. As soon as I can, I start to see what happens ... Greetings.
    La versión de Simtools es la 2.2. Estos días estoy un poco liado con el trabajo. En cuanto pueda me pongo a mirar qué pasa... Un saludo.
    153,986Coins
    +11,162 / 57 / -2
    Try the current version SimTools v2.3.1: https://www.xsimulator.net/community/marketplace/motion-simulation-software-simtools.63/
  16. Daniel_83
    Daniel_83 New Member
    Poland
    223Coins
    Hi, my 3dof does not work well with dirt rally, surge and sway do not work. I saw tips to change the resolution, do not use alt + tab during the game, but it did not helped solve the problem. I have simtools 2.3.1 and Codemasters Dirt Rally Plugin 2.0.0.3
    I noticed that when I am playing in the oculus everything is working properly, the surge and sway are not working on monitors. Any ideas ?
    153,986Coins
    +11,162 / 57 / -2
    Your Rift has no bearing on SimTools, so perhaps your perception of your rigs setup is different in VR. It is normal to use less motion in VR than with monitors.
    Try following these steps to test then refine your motion profile and rig movement, doing one axis at a time: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
    That said Dirt Rally is problematic when it comes to motion, which is why there are now a number of different plugins for it.
  18. splendiddd
    splendiddd Active Member
    CCTV security
    Netherlands
    813Coins
    I never had any problems with Dirt Rally. That said i did make my own profile and edited the hardware xml of the game myself.
    @Daniel_83 How does the tuning center look? do you get the proper values in the tuning center? If that behaves wierd then it might be a double port problem. Try patching the game again.
    Did you try my porfile and min_max value? https://www.xsimulator.net/communit...ts-profiles-and-tips.11273/page-4#post-170908
    If it does not work maybe i can help you via skyp/teamviewer.
    Regards, Rob
  19. cover4x4
    Car Mechanic
    Spain
    68Coins
    2DOF, SCN5
    Hello again. In the end I was able to install the plugins and apply the Path, both Dirt Rally and Euro Truck Simulator 2, but the problems have not ended there because although I have managed to install it, I have not been able to move the engines in any of these two games, the truth is that I do not know what I'm doing wrong .... Simtools works perfectly with Asseto Corsa and Assetto Corsa Competizione, as well as Live for Speed. Also comment that I have games by Steam ....
    Hola de nuevo. Al final he podido instalar los plugins y aplicar el Path, tanto de Dirt Rally como de Euro Truck Simulator 2, pero los problemas no han acabado ahí ya que si bien he conseguido instalarlo, no he conseguido que me muevan los motores en ninguno de estos dos juegos, la verdad es que no sé que hago mal.... Me funciona Simtools perfectamente con Asseto Corsa y Assetto Corsa Competizione, así como en Live for Speed. También comentar que tengo los juegos por Steam....
  20. Daniel_83
    Poland
    223Coins
    I set each game like this:
    I run the game and tuning center (capture min max), I do a clean but fast ride on the track or a special stage, then save the settings in the tuning center for this game, if it is necessary then I correct it and test it in the game.
    Then in axiss assignments I set everything to 0%, and set the value for each option separately, eg first roll set 50% myself and check in game, if it works well, if necessary, I change the directions.
    And so I do it for each option, pitch, sway, surge heave, percentages set individually for each option.
    In dirt rally, if I set everything to 0 and set 50% only for surge then I do not feel anything in the game.
    At other games, like RBR, when I set the same 50% only for surge I feel like the platform rises when I press the gas and falls down when I braking.
    The strangest thing for me is that everything works well when I play at Dirt Rally in oculus rift, but when I turn it off and want to play on the monitor surge and sway does not work, this problem is only for rally and hiclimb, at rallycross platform work fine. For me it is some magic :) I have no idea where is the problem.
