Creazyrider 2DOF for car races and plane
Discussion in 'DIY Motion Simulator Projects' started by creazyrider, Jun 25, 2018.
  1. prodigy
    prodigy Burning revs
    Croatia
    6,698Coins
    You can upload the video to Youtube and put it here
    Or if you don't have Youtube account - you can use https://streamable.com/
    After upload just post a link to the video here
  2. creazyrider
    creazyrider Active Member
    france
    850Coins
    Here is a link of my first video:
  3. creazyrider
    france
    850Coins
    Evolution of the simu
  4. creazyrider
    france
    850Coins
    building the supports for the springs
  5. creazyrider
    france
    850Coins
  6. creazyrider
    france
    850Coins
  7. creazyrider
    france
    850Coins
    Sanding all the simulator before painting
  8. creazyrider
    france
    850Coins
    Painting all the parts
  9. creazyrider
    france
    850Coins
    2nd layer of mat black
  10. creazyrider
    france
    850Coins
    I had a big problem with the 2 motors between the shaft and the gear of the reducer,
    the arm of the motor could move freely about 2 or 3 degrees, the result was that the regulation couldn't work fine and I had some bounds with the movements of the simu
    This is the existing part
  11. creazyrider
    france
    850Coins
    Building the new part
  12. creazyrider
    france
    850Coins
    comparison of the old one (left) 2.5mm thick and the new one 4mm thick
  13. creazyrider
    france
    850Coins
    From the other side of the gear, the new part fastened
  14. creazyrider
    france
    850Coins
    The new part ready to use, I added some tin to fill in the space between the shaft and the new part
  15. elnino
    elnino Active Member
    Computer Geek
    Adelaide, Australia
    1,551Coins
    I see that you replaced the main joint from the CV to a traditional Uni-Joint. Was there any specific reason for this? I have started my build and those joints are super expensive here in Australia so I went with a CV joint - Did I make the wrong decision?
  16. creazyrider
    france
    850Coins
    Hello, yes I think this kind of joint is not good because it can generate some yaw movement that is exactly what you don't want. Maybe you could buy a joint from the steering column, I think it's better.
  17. creazyrider
    france
    850Coins
    I bought a terminal to wire properly all the 230V
  18. creazyrider
    france
    850Coins
    Today I received the end caps
  19. creazyrider
    france
    850Coins
  20. creazyrider
    france
    850Coins
