Question Build my own DD Wheel
Discussion in 'DIY peripherals' started by Ruben Miguel, Oct 28, 2018.
  1. Ruben Miguel
    Ruben Miguel New Member
    149Coins
    Hello everyone, I want to make my own direct drive wheel, which hardware and motors recommend
    152,553Coins
    +11,087 / 56 / -2
  3. Ruben Miguel
    149Coins
    Thanks NoorBeast!
    btw the NEMA 23 1.9nm 2.8A is good for an inexpensive project?
  4. Gadget999
    12,035Coins
    search for "Cousin of OSW"
  5. electrolux
    electrolux New Member
    63Coins
    Stepper motors are no good for FFB wheels as far as I've been able to find, look at the thread @Gadget999 mentioned above.
    If you're on a budget you're probably best off having a belt or gear drive, a basic FFB wheel needs to have 4-5Nm of torque and a motor that can produce that much for DD is expensive.
  6. Gadget999
    12,035Coins
    there are plenty of cheap DC motors that can be used for a DD - the first thing a racing driver will do when they use a DD wheel is reduce the power to make it feel more realistic
    look for the ty1020 motor
  7. BS21
    BS21 Sim Tutorial: www.youtube.com/BSGamingSimulator
    Indonesia
    193Coins
    DC motor
    Maybe you wanna see my build. I used MY1016 but using belt driven and they running with MMOS.
    My build:
    My test:
  8. electrolux
    63Coins
    How do you think a weaker motor would work? I am thinking of using the 150W MY6812 with 1:7.5 belt drive.
    EDIT: Nevermind, 250w MY1016 is only £5 more so much better.
  9. Ruben Miguel
    149Coins
    So is a dc motor better than a motor stepper or servo motor ?!
  10. Gadget999
    12,035Coins
    use a servo or DC motor - a stepper motor is designed to apply power in steps so is not as suitable - but they can be made to work
  11. BS21
    Indonesia
    193Coins
    DC motor
    I think 100w motor is better because it is colder and still can result high torque by increasing the ratios..
  12. Gadget999
    12,035Coins
    The cost of a good motor needs to be offset against the cost of gears and belts
    It works out better to build a direct drive wheel with a good motor imo
  13. Ruben Miguel
    149Coins
    Hi guys, so I realized the dc motor and servo motor are good, but the servo motor are very expensive so I will opt for DC
  14. elnino
    elnino Active Member
    Computer Geek
    Adelaide, Australia
    1,551Coins
