Question started my 2 dof project
Discussion in 'DIY Motion Simulator Projects' started by phonghornet, Oct 28, 2018.
  1. phonghornet
    phonghornet New Member
    190Coins
    2DOF, 3DOF, DC motor, Arduino, 4DOF, 6DOF
    Before building the moving hardware, I wanted to test the operation of the motor before but encountered some difficulties:
    experiment with SMC3Utils v1.01 and simtool 2.3 they have been active.
    But when I connected the game I did not see any vibration.
    152,355Coins
    +11,075 / 56 / -2
    LFS has to be run in first person mode before being patched, to generate some necessary files.
    So un-patch LFS, then shutdown SimTools.
    Run LFS and drive a couple of laps.
    Start SimTools then re-patch LFS.
    Test all is working as expected.
  3. phonghornet
    190Coins
    sorry @noorbeast .
    I use google translate, cannot determine your answer answer.
    you have 1 link or video about patch lfs?
    152,355Coins
    +11,075 / 56 / -2
    No video.
    Remove patch.
    Close SimTools.
    Run LFS and drive some laps.
    Start SimTools.
    Patch LFS.
    Test LFS.
  5. phonghornet
    190Coins
    thank you @noorbeast
    I will try again and wait for the results
  6. phonghornet
    190Coins
    I have try again, but they still again.
    I know unknown where?
    152,355Coins
    +11,075 / 56 / -2
    Have you created an Axis Assignment for LFS, as that is required.
  8. phonghornet
    190Coins
    Hi @noorbeast
    I tried several times. delete and reinstall but still not.
      226.2 KB
      519
      175.9 KB
      487
      92.4 KB
      533
  9. phonghornet
    190Coins
    Hi @noorbeast
    Is simtool and lfs only works from win8 or win 10?
    I deleted the patch and ran another round on another laptop. But the motor stayed still.
    All my computers are using win7 32 or 64bit
    152,355Coins
    +11,075 / 56 / -2
    SimTools works with all versions of Windows, 32 or 64 bit, except for XP.
    Can you please confirm you have created a motion profile for LFS and post a picture of it.
    Also shut down any firewall or antivirus temporarily and make sure there are no processes running for either.
    Then remove the LFS patch.
    Close SimTools.
    Run LFS in Single Player first person mode and drive some laps.
    Start SimTools.
    Patch LFS.
    Test LFS.
  11. phonghornet
    190Coins
    I will post my computer image.
  12. phonghornet
    190Coins
  13. noorbeast
    152,355Coins
    +11,075 / 56 / -2
    Output Testing verifies that SimTools is working OK, the issue is either with your settings for LFS or something is blocking LFS like Firewall or Anti-Virus.
    Your Tuning Center picture shows it is set to Output Testing when it should be set to LFS.
    So I need your to please verify and do the following:
    Please post a picture of the Axis Assignments for LFS.
    Please post a picture verifying LFS is patched correctly.
    Please post a picture of the Tuning Center while LFS is running and LFS is the Game Selected.
  14. phonghornet
    190Coins
    I will do the turn.
    No. 1
    152,355Coins
    +11,075 / 56 / -2
    Please use the Single Player mode to do the laps in LFS, not the Training mode.
