How to get X-sim data?
Discussion in 'New users start here - FAQ' started by sSnake, Jun 6, 2009.
  1. sSnake
    sSnake New Member
    0Coins
    Hi all, I'm new here, I googled this amazing software just now and I'm so excited to find this software :D
    I'm now building up an outgauge by a sigle-chip-microcomputer (89S52), I've almost finished my project and it works all fine with LFS.
    And I believe you may know, before I know the x-sim, to getting LFS data, I just need to acquire a network packge from 127.0.0.1, I've write a small program via VB6 and the program do a little translation of the data and send it to a sieral port, to which my hardware is connected, and another program I wrote in the sigle-chip-microcomputer reads the data and then do some work to control the leds, numerical code tube etc. ( I want to extend the hardware later by adding the LCD module, or even motors, .....all based on the control by the microcomputer) you can watch the device here:
    http://www.youtube.com/watch?v=tKrYAnuilgc&feature=related
    But since I'm not professional on programming, I'm not able to get other games' data, and that's why I've found the X-sim and asking help now.
    Reading through the manual file, it seems that, although x-sim is able to read data from various of game, but the output of x-sim is only to real actuators, is it possible to trasmit the data read from x-sim to my own program? If so, how to do it?
    I'm very appreciated if you can help me, and again, nice to meet you all!
    Greetings from Shanghai, China
  2. RaceRay
    Hamburg, Germany
    23,876Coins
    a warm welcome from me :)
    Please read the manual of the X-Sim software. You are able to send values like speed, temperature, gear and many more via x-sims internal USO interface to a rs232 device of your choice. That can be a real one or a virtuell device.
    You can try to install any virtual rs232 driver and should be able are able to send the data to. Alternatively you can use the x-sim api to make your own programs. For detailed programming questition please ask sirnoname.
    X-SIM docs -USO:
    http://www.x-simulator.de/wiki/Read_more_about_the_Universal_Serial_Output_(USO)
    regards
  3. sSnake
    sSnake New Member
    0Coins
    Thanks for the reply Raceray :)
    I think the mapping RS232 approach is a bit complex, besides, I should decode the formatting of the RS232 data sent by X-sim before I can use the data of my own.
    I'm more perfer to use the API of X-SIM, but the URL you sent seems unworkble
    BTW, I've found some articles about the MMF, is it the way to get X-SIM data?
  4. RaceRay
    Hamburg, Germany
    23,876Coins
    Another try with the URL :)
    i repaired the link.
    regards
