DOF Reality platforms presets, profiles and tips
Discussion in 'Commercial Simulators and Peripherie' started by Mpmo, Dec 9, 2017.
  1. noorbeast
    153,758Coins
    When filters are being used screenshots are not particularly useful, unless they include the Filter settings. You can use the Preset button in Axis Assignment then make a Preset and instead upload that file.
    As an aside the Axis Assignment total is 550%, which is likely to induce clipping.
  2. RAHULUS
    RAHULUS New Member
    99Coins
    Are these iracing settings correct?? My H3 feels like a bucking bronco!
  3. optical10
    optical10 Member Gold Contributor
    694Coins
    Can anybody share their settings or a zipped file for project cars where the movement isn't unrepresentative of what's going on whilst in the cut scenes and in the game racing?
    It seems that even when the engine is running on the cut scene that the traction loss is swaying erratically and even if you turn down the main level in profile editor down it doesn't have much of an effect. Also acceleration and braking as well as the other axis movements don't correspond in game.
    This is the only game where I have this issue for instance PC2 plug-in works flawlessly as well as Dirt4, Dirt Rally and F1 2017 now that I have sorted out the language region bug not being set to US causing plugins and USB communication to act erratically.
  4. splendiddd
    splendiddd Active Member
    CCTV security
    Netherlands
    813Coins
    Make sure you use the Project Cars 2 UDP PC plugin and set ingame the UDP to 1. (options -> system settings)
  5. optical10
    694Coins
    Many thanks my friend as I ended up using Project Cars UDP PC plug-in rather than the PC2 UDP PC plug-in you suggested but because I used your in game UDP setting set to 1 in options suggestion it now working flawlessly similar to PC 2 plug-in anyway so it's a win-win :) .
    I'm not sure how I would have used another games plug-in, PC2 in project cars as you suggested, can you explain please?
  6. rick mitchell
    rick mitchell New Member
    183Coins
    2DOF, Motion platform
    does anyone have any good settings for asseto corsa competizone they would like to share. would be very much appriceated. for dof reality
  7. splendiddd
    CCTV security
    Netherlands
    813Coins
    It depends on what plugin you patched the game with i guess..
  8. IntrudR
    IntrudR New Member Gold Contributor
    124Coins
    Newest settings (H3/P3) for X-plane. Should also work for H2/P2 out of Extra3
    Unzip under C:\Users\<yourUser>\AppData\Local\SimTools\GameEngine\AxisAssignmentsPresets\Generic2DStandard_Presets\ and load it in the Game Engine under Axis Assignments. After that set the values in the tuning center according my screenshot.
    BR
    Fabian
  9. xxpelle
    xxpelle Discord "TPMax#9574" Gold Contributor
    713Coins
    for the settings in the a-axis, the values are so high to check the effects of the individual movements.
    with the settings in the b-axis my g-seat servos are controlled. an override is not important.
  10. greatg67
    greatg67 Member Gold Contributor
    509Coins
    Need a bit of help. I had a systems crash and reinstalled all of my sim games. I'm now trying to configure XPlaneII. I followed the steps, but I keep getting this pink box and it will not allow me to tick "send network data output"?
    153,758Coins
    Is this what you are following, as I can't tell from the image you posted, as it does not show all the settings: https://www.xsimulator.net/community/faq/x-plane-11-setup.288/
  12. splendiddd
    CCTV security
    Netherlands
    813Coins
    Hi Guys Here are my settings for Dirt Rally, Dirt 2, Dirt 3, Dirt 4, PC1 & 2 Iracing, AC, ACC F1 2018, RFactor 2 and Elite & XPlane.
    WARNING! Backup your files! especially the min/max ones! I think you can use the plugininstaller or copy manually to /local/simtools/gameengine etc..
    I use for allmost all profiles except the Dirt ones 75 - 75 - 90 axis limiting. Dirt Rally as seen below is at full 100%
    In action, more video's will follow soon:
  13. greatg67
    509Coins
    For those that have a P6. Do you have any presets that can be shared?
  14. Daniel_83
    Daniel_83 New Member
    Poland
    223Coins
    Hi splendiddd, amazing movie, your dof p3 work amazing, if it is no problem please zip your simtools with profiles settings etc, and screens from SMC3Utils for each motor (motor1, motor2 and motor3)
    I have Dofreality P3 too, but have some problem with Dirt Rally, surge and sway does,t work, i feel only pitch roll and extra1 (traction loose)
    Your platform have 2 usb ports plug to PC ? 1 for front motor and second for traction loose motor, or you have all plug with one usb cable to your pc ?
    You can sand email to me: daniel.frajda@gmail.com
    Thx and regards, sorry for my english :)
  15. splendiddd
    CCTV security
    Netherlands
    813Coins
    Hi Daniel,
    Did you load the profile in the axis section under Dirt Rally?
    Did you use my Min_max file?
    It should work, ofcourse i can share screenshots, but these files make it much more easy for you.
    PS i use one usb cable from the unit.
  16. Daniel_83
    Poland
    223Coins
    I use axis type Generic 2D basic, but now i see at your file, you use Genric 2D standrad, i try it. But please tell me what preset I must load at axiss assignments ?
  17. marco balletta
    marco balletta Member
    1,445Coins
    Do you have a p6?
    I do have a p6 but I do not think my settings for dirt and project car 2 are well done. I have no experience
  18. splendiddd
    CCTV security
    Netherlands
    813Coins
    Use the Dirt Rally profile that i uploaded.
  19. Daniel_83
    Poland
    223Coins
    Ok, I use it, cen You show me Your settings from SMC3 ?
  20. splendiddd
    CCTV security
    Netherlands
    813Coins
    Sure, but its the same as provided by DOF Reality.
    When i am in the sim again i will upload some screenshots, or even better make a short video of if?
