Race room
Discussion in 'Commercial Simulators and Peripherie' started by MADERN, Nov 2, 2018.
  1. MADERN
    MADERN Member Gold Contributor
    Decorater
    538Coins
    SCN5, SCN6, Motion platform, 4DOF
    Hello guys hope someone can help, downloaded plugin for race room when you click the drive button the rig starts going crazy , when you try to drive the car it seems like everything is connected to traction loss ie steering, accelerator, brake , I will try to upload video, it shows the rig moving left to right really fast
  2. MADERN
    Decorater
    538Coins
    . Video of race room rig problem
    152,349Coins
    +11,074 / 56 / -2
  4. MADERN
    Decorater
    538Coins
    Hello this might sound mad but I’ve never touched tuning center before I’ve only downloaded plugins for ac, ac2,pc2,rf2 and they have all worked straight away. The axis assignment are what was default is and all outher games are the same and work really well,race room is the first game that has done this , I am complete novice at this so any help would be great. DAVE
    152,349Coins
    +11,074 / 56 / -2
  6. MADERN
    Decorater
    538Coins
    I am sorry I have no idea how to check language, I searched pc for region and language it came up with no matches ,I will get some help with this tomorrow, while I was waiting for a reply I adjusted values in assetto corsa down to about 25% on each axis and yes it moves but not very much, I have 100mm movement actuators, in game when accelerating hard the actuators moved about 25 mm the same with hard braking and hard cornering , I’ve sort of got use too more movement
    Dave
    152,349Coins
    +11,074 / 56 / -2
    In Windows 10 go to Settings and then Time & Language and you will see Region & Language in the left hand side bar.
    You need to go through the whole process of refining a motion profile, not just dump some values in and expect it to work. Not moving very much suggests the Tuning Center values are too high. And for some Axis assignments, like sway and roll, you will want a bit more than 25% Axis Allocation.
  8. MADERN
    Decorater
    538Coins
    Thank you very much I will spend sometime tomorrow on your suggestions , I will let you know How I get on, meanwhile I set traction loss to zero in axis assignments and raceroom works perfectly but obviously no traction loss so must be problem with extra1
    Dave .thanks again
    152,349Coins
    +11,074 / 56 / -2
  10. MADERN
    Decorater
    538Coins
    Raceroom issue, worked out how to use tuning center did a capture in min and max saved it and yes when I turned traction loss on the rig stopped shaking and was useable, I am changing settings in axis assignment but with low settings there is only small movement it’s made better with the main power turned up to 100%. With the outher games the axis assignment is a lot higher but I run main power at 80% that gives a good feeling of movement.i dont understand why my outher games I never needed to touch tuning center they just worked immediately. Thank you for all your great advice
    Dave
  11. Einar
    Einar New Member
    182Coins
    Motion platform
    I have the same problem with raceroom. Yesterday I was finish assambly my rig and installed Simtool, patched Project cars2 and Raceroom. PC2 worked fine, but raceroom was completely wild on tractionloss before the car moved at all. Could it be something wrong with the plugin? As new as I am to this I dont feel for fidling around in tuning center yet, just want Raceroom work easy like PC2 did.
    152,349Coins
    +11,074 / 56 / -2
    It is far more likely that your motion profile is the issue, here are the steps to create and refine a motion profile: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  13. Einar
    Einar New Member
    182Coins
    Motion platform
    I am not able to run Raceroom it is nearly trowing me out of the seat. Can I create this profile in PC2 and it will most likely fix RR?
    152,349Coins
    +11,074 / 56 / -2
    Not really a good idea, as a profile should be dialed in for a specific game, but your Default profile should be tweaked to be a generic starting point for new profiles.
    Instead under Axis Assignments temporarily turn Axis Limiting right down, the as per the earlier link do a capture of Max/Min values in the Tuning Center for RRE. If you have sensible Axis Allocations that should settle things down enough to be able to raise Axis Limiting again and then tweak the profile from there, doing one axis at a time.
  15. MADERN
    Decorater
    538Coins
    Hello EINAR I just tweeted raceroom in tunning center and it works perfectly my problem was that traction loss was on ‘0’ as soon as I adjusted this value the rig worked perfectly, I still have problem with pc2 so I just don’t play it anymore, you will have great time on your rig it’s all about fine tunning each game
    Good luck, Dave
  16. Einar
    Einar New Member
    182Coins
    Motion platform
    Traction loss on mine is on 90. So I realy dont understand why it is moving left to right to left .... imidently when past the menu. A step by step for dummys would be great.:grinhug:
  17. MADERN
    Decorater
    538Coins
    90 in axis assignment sounds ok, but in tunning center I think it should be 7 to -7 . I’m not near mr rig at the moment but I will post some pictures of my settings for raceroom
  18. Einar
    Einar New Member
    182Coins
    Motion platform
    :) Thanks looking forward for more info.
  19. MADERN
    Decorater
    538Coins
    Ok here are my settings for raceroom, I am only a beginner myself and are regularly tweaking my settings, hope these pictures help.Dave
  20. Einar
    Einar New Member
    182Coins
    Motion platform
    Thank you, now I was able to run Raceroom.hug:
