Iracing SCN5 100mm profiles
Discussion in 'X-Sim² profiles' started by Ringorumble, May 1, 2009.
  1. Ringorumble
    Ringorumble Active Member
    190Coins
  2. Ringorumble
    190Coins
    Sorry, put the wrong speed and accel here,
    use speed 4000
    and accel 100
  3. njracer
    njracer Member
    2Coins
    hey ringo, i can't see to unzip your profiles, can you check them and make sure there still good?
    thanks
    dave
  4. Ringorumble
    190Coins
    Upss, just rename em to .rn2
  5. njracer
    njracer Member
    2Coins
    hey ringo, can you give me an example? i tried impalatruck.rn2.zip and it didn't work, i'm sure thats not what you meant, can you show me what you mean?? i have to extract it right? or do i just pop it in the force profiler?
    thanks
    dave
  6. egoexpress
    egoexpress Active Member
    Germany - Frankfurt/M
    422Coins
    Remove zip, and place rn2 instead! :whosthere:
    impalatruck.rn2
  7. Ringorumble
    190Coins
    Ego is right !
  8. njracer
    njracer Member
    2Coins
    that did it, thanks ego :cheers:
  9. njracer
    njracer Member
    2Coins
    hey ringo, did you change the speed already in these profiles or do i still have to do it??
  10. Ringorumble
    190Coins
    You have to, i think ... i only use one since months .. after using another i had to change it again ..
  11. njracer
    njracer Member
    2Coins
    you think you can upload the new one?? :blush:
  12. Ringorumble
    190Coins
    No, i have no new one i use the radical one
