G-Seat Project
Discussion in 'DIY Motion Simulator Projects' started by Michal Burisin, May 1, 2018.
  1. Michal Burisin
    Michal Burisin New Member Gold Contributor
    Prague
    138Coins
    To put this project in context of the whole rig, here's the thread to the general rig build on RD forums, up until now I was wresting with tactile, now that is done, I can focus on G-Seat :)
  2. Michal Burisin
    Prague
    138Coins
    I have done little bit of tweaking to the shape and I also corrected lines along which paddles will be bent:
    On the right side, there is overlay before / after. With side paddles I can push the size very close to the limits, as I can move it as necessary. On the main paddles, I'm leaving some margin for error.
    I would have question for current G-Seat users.
    Should I extend the back paddle more down to the butt? All g-seat projects I have seen has paddles above the butt it seems. Does it have a reason and should I do the same or it could beneficial to have the paddles all the way down.
    Only reason I figured, it could be because the butt wouldn't move, and it would overstress the servos and limited the felt effect, any ideas?
    Thanks.
  3. sberns
    sberns Member Gold Contributor
    432Coins
    3DOF, SCN5, Arduino
    Hi Michal, I tried lowering the back panels temporarily on my DIY Gseat and found the effect underwhelming. I also think it increased the load on the servos. For both reasons, I raised them back up to a normal position.
  4. Michal Burisin
    Prague
    138Coins
    Thanks, I will leave it as it is then :) If it would give me trouble even like this, I can always cut more from the bottom myself.
    I have finalized data and sent query for manufacturing. I hope I measured everything correctly, I triple checked :)
    I asked for 4 mm aluminium material in order to be sturdy enough to handle the tactile without resonance. Maybe 3 mm would be enough, but I'd rather be careful here.
  5. Michal Burisin
    Prague
    138Coins
    So the paddles are here!
    Now I need to finish the 3D printer and learn with it to be able to attach them to the seat.
    I also got aluminium plates for peripherals. I probably should have gone for some irregular shape to make it look cooler and not so boxy though :) It's 8 mm aluminium. It will be easy to do flush mount attachment so it won't interfere with anything.
    • Like Like x 6
  6. RacingMat
    21,082Coins
    Hi @Michal Burisin
    Very good work so far :thumbs
    what's new? please keep us posted :cool:
  7. RacingMat
    21,082Coins
