Question Sending basic Simtools Motion data to Arduino via Serial Port
Discussion in 'SimTools DIY Version' started by Lodewijk, Sep 4, 2017.
  1. Lodewijk
    Lodewijk Member
    Engineer
    South Africa
    597Coins
    4DOF
    Simulator
    Commercial or DIY: DIY
    DOF (Number of axles ): 1
    Actuators (DIY, SCN5 etc.): Servo motor
    Interface (Arduino, SCN, Mega, DIY etc. ): Arduino
    SimTools
    Version Number: 2.1 Demo
    Game Plugin where the error is happening: Live for Speed
    Settings (Relevant settings) As outlined in post below
    I would like to set up a small test to send Simtools motion data (just one axis for now) to Arduino Serial Monitor. At the moment I don't have any actuators coupled, I just wanted to get a few LEDs or small servo motor turning witht motion data from Simtools.
    I have set up the Simtools Game Engine to write to COM16, 9600-8-N-1
    I have also set up Arduino to listen to COM16, 9600-8- N-1
    I then run LFS, and I get data out on the virtual axis, as well as on the Tuning Centre
    I don't however see anything on the Arduino Serial Monitor. I must admit, I only ever programmed my first Arduino this past Saturday, so I might be having a problem there.
    What am I missing?
    How should I configure Simtools, and Arduino to get just a simple 1 axis motion data to control a servo via Arduino? Any assistance would be highly appreciated.
  2. yobuddy
    51,659Coins
    Select an output rate and click save buddy.
    Then try again and you should be golden!
  3. fourteenary
    fourteenary New Member
    299Coins
    2DOF, 3DOF, Arduino
    Hi Lodewijk
    Have you solved this issue? I am trying to DIY a 2DOF seat and I meet with the same issue now.
    Thanks,
    Marvin
  4. yobuddy
    51,659Coins
    @fourteenary,
    The problem is in the first pic he posted.
    You can see in the pic that the interface output has no 'Output Rate' selected.
    And the save button is not enabled, meaning the settings are incomplete and have not been saved.
    Basically, the problem here is there is no saved settings for the interface.
    Take care,
  5. fourteenary
    299Coins
    2DOF, 3DOF, Arduino
    Thanks yobuddy
    I got an advice in another thread, I will try that way to have the test.
  6. Lebois
    Math teacher
    2,566Coins
    Did you found a solution ? I have quite the same problem...nothing works... Arduino doesn't seem to receive datas...
  7. yobuddy
    51,659Coins
    @Lebois,
    The problem was the settings were never saved.
    I can tell because if you look in the pics above, you can see there is not enough info in the interface section to enable the save button to use.
    Take care,
    154,400Coins
    +11,181 / 57 / -2
    Saying you have a problem, without posting details, such as pictures of all of your settings, give members little to go on in terms of giving advice.
  9. Lebois
    Math teacher
    2,566Coins
    I posted all the details on my problem on a new thread here, but I didn't solve it...
    Maybe you could have a look to it ? :)
  10. yobuddy
    51,659Coins
