SMC3 Sabretooth TEST version
Discussion in 'SimTools compatible interfaces' started by RufusDufus, Jan 25, 2015.
  1. shaman
    shaman 2dof sim
    Moscow
    - 965Coins
  2. BlazinH
    16,642Coins
    You'll have to do more than just add motors to the sketch if you want it to run properly. Your smart move would be to go with the sketch noorbeast suggested or to use two arduinos but suit yourself.
  3. Evan Rowlands
    Evan Rowlands EMR Industries
    Melbourne Australia
    - 82Coins
    must easier and better with 2 uno's
  4. Pit
    30,463Coins
    Good luck. I don't see the point, anyway each to his own. If you should have successfully coded a working scetch honestly let us know.
  5. shaman
    shaman 2dof sim
    Moscow
    - 965Coins
    Everything works fine. To connect 2 Sabertooth 2x32 need, In packet serial mode, DIP switch 5 sets the packet serial address. The ON position sets address 128, and the OFF position sets the address to a user-definable alternate 129.
    In SMC3 sketch uncomment the line 1549-1585 for 3 motor work.
  6. Pit
    30,463Coins
    From the thread you have quoted: "UPDATE Beta5 to Beta 6 on Nov 12, 2016 - commented out motor3 to optimize serial execution speed and because it likely won't be used anyway since only one motor channel on a second sabertooth can be used.
    Anyway let us know if you got 4 motors or more working with just one Ard. We are here because we never give up ;)
  7. shaman
    shaman 2dof sim
    Moscow
    - 965Coins
    Hi.
    connected yesterday 3 of the motor. everything works fine.
    1 Arduino uno and 2 Sabertooth 2x32. 13 pin for Sabertooth 1 (address 128) for motor (1,2) and 13 pin for Sabertooth 2 (address 129) for motor (3). DEscribe 115200.
    in the sketch Sabertooth ST[2] = { Sabertooth(128, mySerial), Sabertooth(129, mySerial), };
    simtools work fine [A<Axis1>][B<Axis2>][C<Axis3>] Baud rate 500000
    150,025Coins
    +10,993 / 54 / -2
    You must not be using SimTools 2 if those Input Settings work, as they are from the old SimTools 1.3.
    The difference from SimTools 1.3 to SimTools 2 in setup is that in the Interface Settings instead of axis defined like this <Axis1> it now has designate grouping for a or b in SimTools 2 for each axis assignment, like this <Axis1a>
  9. shaman
    shaman 2dof sim
    Moscow
    - 965Coins
    Yes I use SimTools 1.3
    150,025Coins
    +10,993 / 54 / -2
    Please be aware that current plugins are not compatible with SimTools 1.3.
    Conditions apply but eligible DIY motion sim builders can request a free DIY SimTools 2.0 license, see here for details: https://www.xsimulator.net/request-diy-key-simtools/
  11. BlazinH
    16,642Coins
    Did you ever stop and ask yourself why someone would make the effort to add the necessary code for a third motor only to comment it out? Does it work, yes. Does it work fine, only if you don't mind signal clipping.
    Most people that can afford to build a rig can afford one more uno too in order to gain additional processing power but again suit yourself.
  12. shaman
    shaman 2dof sim
    Moscow
    - 965Coins
    Ok. I also have SimTools 2.0 Pro. I use both versions.
    as the simulator will be ready, I will show the video
  13. Pit
    30,463Coins
    fine, but then open a new thread in the appropriate forum. Thanks.
  14. Wanegain
    Wanegain Active Member
    Bruxelles
    1,993Coins
    I wrote a sketch which can drive 3 Sabertooth 2x32 (6 motors) on one Arduino. As they are communicating using serial, it's not a big deal to have up to 6 motors on one Arduino (not Uno because I always keep an analog input to set the global power of motions).
  15. BlazinH
    16,642Coins
    That's great but were talking specifically about the SMC3 sabertooth sketches. I agree though its no problem driving 6 motors with an arduino . In fact you can drive up to 48 motors from a Mega if you want to but it all depends on how robust the PID control is and therefore how much time it takes to execute for each motor.
  16. sci666
    1,146Coins
    Does this Version also works in Mode 2? I Just cloned my sabertooth setting arduino but want the additional Operate in Mode 2 with the cheap Motor driver
