A simple VR rollercoaster
Discussion in 'Ready, set, go - Start your engines' started by Robert Chua, Nov 17, 2018.
  1. Robert Chua
    Robert Chua New Member
    172Coins
    anyone here got an idea on how to make a 4D Rollercoaster VR ? we are having a problem on how to make a motion chair and what materials we will use ,please help us any idea? We want to build it with a low budget.
    153,716Coins
    Have a look at existing member builds, that may help you refine your own project ideas and prefered design: http://www.xsimulator.net/community/forums/diy-motion-simulator-projects.22/
    You will find plenty to get you started in the FAQs, from design software, dimension of sims, to PSUs, pots, motors, control boards, plus heaps more: http://www.xsimulator.net/community/faq/
    We have a glossary for all those acronyms we tend to use, which will help you decipher some descriptions: http://www.xsimulator.net/community/faq/glossary-of-acronyms-and-names.66/
    Feel free to ask questions on your build thread, the members here give freely of both their time and expertise.
    Good luck with your rollercoaster sim project.
  3. Robert Chua
    172Coins
    thanks for the help.. Just wanted to ask if all linear actuator are good to use for the motion chair?
  4. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    it depends. For racing is the best choice. But for general purposes, many other options exists, like a electrical motors.
  5. Robert Chua
    172Coins
    ahhh ok sir, our project was a 2 sitter chair :( .. Do you have some kind of ideas on what materials should we use?
  6. Robert Chua
    172Coins
    will this kind of actuator be fine for a roller coaster chair?
    153,716Coins
  8. Robert Chua
    172Coins
    Guys I gave up on using a linear actuator, I am thinking of using a DC motor. Can someone help me on what kind of motor should I use and its specs :(
    153,716Coins
  10. Robert Chua
    172Coins
    Will a 12v worm gear motor be enough sir?.. It has a 200w, 180rpm and 20Nm torque :)
    153,716Coins
    Those DC motors are ideally suited to shoulder mount designs. But again you need to finalise and provide a design before people can really comment on what motors to use with the chosen design.
  12. Robert Chua
    172Coins
    This is the design that I want to follow sir :)
  13. BlazinH
    16,689Coins
    Yes they should be okay for that kind of rig.
  14. prodigy
    prodigy Burning revs
    Croatia
    6,698Coins
    Is that simulator presented somewhere in the forum?
    I would like to know what seat is that?
  15. Robert Chua
    172Coins
    I found it in youtube sir :)
  16. paulopsx2
    brasil
    647Coins
    A huge amount of people make this project here. See on projects posts
  17. prodigy
    Croatia
    6,698Coins
    Thanks, but I know about other projects, I am just interested in the seat type from that screenshot.
    Can you post a link please?
  18. MarkusB
    4,215Coins
    Hi Robert,
    since you are heading for a roller coaster simulator, you should consider the following:
    The picture in your post shows a seat mover, which means that only the seat itself moves while your feet stay fixed on the ground.
    This kind of simulator is suited for rather small pitch and roll angles, like for racing games where you want to feel road bumps and small, hard acceleration movements.
    Due to my own experience, a seat mover is not suited for larger pitch and roll angles, which you may want to have in a roller coaster simulator.
    Imagine a roller coaster going up or down a hill, which means that your seat leans backward or forward. For simulating such pitch angles you may want to have some larger movements. Not too large, but an overall angle of 10-20 degrees is reasonable for me. The same is true for the roll axis.
    If your feet don't move together with the seat, you will feel your knees stretch and bend while your seat moves backward and forward, which feels very unnatural. After I made exactly this experience with my initial seat mover build, I started immediately converting it into a full frame simulator in which the entire body is moved. That means, your foot rest (or pedal mount) is connected to the moving seat.
    For such a build you probably need stronger motors. Also this was an experience I made, because my initial motors were far to weak.
    @noorbeast was asking you where you are located, because some motors are easier or harder to get depending on the country or continent in which you are living.
    Of course you can start with a seat mover build and maybe you will be totally lucky with it, since the personal sensation of the simulated motion is a very individual thing. Besides, the building process can represent a large part of the overall fun with such a project. However, every iteration on your build costs money, so that initial design considerations like those above can save costs.
  19. Robert Chua
    172Coins
    A
    thanks for the info sir :) .. I'll keep that in mind :) .. I'm located in the philippines sir and sadly I cant find the motors or actuators for this project in our country :(
  20. Robert Chua
    172Coins
    Thats the one sir :)
