Question Game Manager Not Connected
Discussion in 'SimTools DIY Version' started by alberto_sv86_, Nov 25, 2018.
  1. alberto_sv86_
    alberto_sv86_ New Member
    155Coins
    Good evening, I've spent the whole afternoon trying to make the motion work and the game manager does not connect me to see if someone can give me a cable, thank you very much and greetings!
  2. yobuddy
    51,004Coins
    Cable?
    I don't understand buddy?
  3. alberto_sv86_
    155Coins
    I mean that the game manager does not connect, I can not make my 2DOF work, I spent the whole afternoon trying to move it but I can not get it to connect, I put pictures to see if we can find the solution, thanks
  4. yobuddy
    51,004Coins
    1) What do your axis assignments look like for the game?
    2) Are you on a Single PC installation of SimTools, Or a dual PC installation?
    3) Have you played with the IP settings any?
    Chat soon!
  5. alberto_sv86_
    155Coins
    The assignments that I have put in the axes are those that appear in the photo, this installation of sim tools I have only installed it on a PC, it is the first time I install simtools and I am having to make the motion work, I put the ip from my house.
    Thanks for helping me yobuddy the informatica is not mine hehe, a greeting!
  6. yobuddy
    51,004Coins
    Like @moaale mentions (thanks for the assist buddy!) is that when you install a single installation of SimTools, both IP's are already set correctly.
    But if you happened to change them, simply set them back to 127.0.0.1.
    Once you have the IP set, please unpatch, and then re-patch your games.
    Next, what simulator are you trying to get working?
    Or what are you using for the interface?
    Arduino and SMC3?
    We just need a bit more info in order to get you going buddy.
    Take care man!
  7. alberto_sv86_
    155Coins
    Buenas tardes, lo siento por el retraso pero he estado muy ocupado esta semana, al final me dieron el movimiento con Assetto Corsa, el error estaba en el IP, lo pongo como yobuddy dijo He resuelto el problema, la cosa es que con rFactor2 no me funciona el movimiento he mirado otros hilos y en las opciones del juego miré si había activado la opción de simtools y si se activó, no sé dónde está el fallo puede ser, el plugin es ya parcheado y parcheado, con respecto a lo que yo uso, estoy usando smc3 con Arduino, aquí os dejo el enlace de mi proyecto, un saludo y gracias por contestar.
    https://www.xsimulator.net/community/threads/2dof-project-with-12v-engines.12710/#post-166835
    152,015Coins
    +11,061 / 56 / -2
  9. alberto_sv86_
    155Coins
