Question Aluminium or Steel for DIY simrig
Discussion in 'New users start here - FAQ' started by Marv, Nov 30, 2018.
  1. Marv
    Marv New Member
    Vehicle Engineering Student
    166Coins
    Hello everybody,
    this is my first thread ever, I hope this is the right place and right way to do this.
    Im planning on upgrading from a G25 to a DD wheel, most likely a SimuCUBE OSW. My current rig is not suited for the torque a DD wheel delivers so I am planning to weld a new one. These are my goals from the new rig:
    • High stiffness for detailed feedback while still being light
    • Possibility to expand to full motion rig (not a seat mover)
    • High adjustibility
    • Good ergonomics
    • Good cable management
    • Easy access to mouse and keyboard
    • Solid mounting point for VR without vibration
    • Price of about 150€
    I am designing the rig in Fusion360 and I will post the progress in a few days.
    While designing it I had two questions in mind:
    • How big / thick should the square tubes be?
    • Which material should I use for the best weight to stiffness ratio?
    Thanks for any answers in advance.
    Any advice is welcome.
    153,728Coins
    Your questions really depend a fair bit on how the wheel stand is designed and braced.
  3. AussieSim
    AussieSim Member
    Australia
    1,452Coins
    Take a look at fasttracksims, their original designs are welded steel tube, and their newer design is aluminium sheet. (Although just materials alone will be much more than your budget)
    https://facebook.com/FastTrackSims/
  4. Marv
    Marv New Member
    166Coins
    Yeah that’s pretty important I guess. :p
    I am mainly using 35x35x2 in my model now, tommorow i will post some pictures of it.
    Yet I’m still interested if Aluminium is stiffer if I adapt the tube sizes and end up with the same weight compared to the steel rig.
  5. Marv
    Marv New Member
    166Coins
    Thanks for the link, sadly I didn’t find a tube rig though.
    I already checked, the steel tubes would cost ~ 100€.
    Them switching to aluminium is a good indicator of it being a better suited material, eh?
  6. AussieSim
    AussieSim Member
    Australia
    1,452Coins
    The aluminium was for flat pack shipping, whereas the welded steel tube tc-r1 would probably need a wooden crate.
    https://www.isrtv.com/forums/topic/14358-fts-tc-r1-review/
  7. Marv
    Marv New Member
    166Coins
    I ordered all the tubes that I need for the rig (hopefully).
    I decided to go for 35x35x2 steel tubes for the main structures, as steel and aluminium have the same specific modulus (stiffness-to-weight-ratio) while steel is less expensive. I hope it wont flex...
    The steel plates in the model (wheel plate and pedal plate) will be about 3mm thick.
    The design I went for is inspired by the GT1 Evo Sim Racing Cockpit from SimLab.
    I'm open for suggestions and inspiration before I start welding.
  8. grec pastor
    grec pastor Member
    Spain
    453Coins
  9. Marv
    Marv New Member
    166Coins
