MotoGP 18 telemetry
Discussion in 'SimTools Plugins' started by Wotever, Dec 1, 2018.
Tags:
  1. Wotever
    Wotever New Member Gold Contributor
    - 261Coins
  2. yobuddy
    51,560Coins
    @Wotever,
    It looks like Pitch and Yaw are listed.
    Along with Surge and Sway (LongitudinalGforce & LateralGforce)
    But I don't see Roll or Heave, could those be the 2 unknowns in the structure?
    Thx buddy & take care,
  3. Wotever
    - 261Coins
    I don't think so,
    For my own usage I've used suspension position smoothed to guess it, but I don't see it in the properties listed on SRT. I have an excel file somewhere with the remaining "unmapped" properties VS SRT list, I will try to find it.
  4. Wotever
    - 261Coins
    I took back my listing, if I made no errors this is the data I've not been able to map :
    Wheel slip angle
    Tyre wear
    Brake temperature
    Slipstream effect
    Wheel inertia factor
    Tyre wearing enabled
    World right vector
    Velocity vector
    If i remember correctly i had almost the finger on Tyre wear but data was looking a bit weird.
    Edit : I sent a few messages to milestone to get some infos and got a few other people trying too, but no luck :(
  5. BlazinH
    16,691Coins
    That's unfortunate. Roll and heave (along with pitch) are both essential for a somewhat realistic motorcycle simulator. Speed is almost essential too.
  6. value1
    14,244Coins
    Thanks a lot for your valueble investigations, @Wotever!
  7. ffb.boy.30
    ffb.boy.30 New Member
    445Coins
    Sorry to re-activate this post but like BlazinH said it is a shame to not have the roll and heave.
    I've looked at the value you called Sx And it looks like a quaternion but I don't know how to extract them.
    If someone have informations it will be great for this plugin .
  8. hideki
    hideki Active Member
    Spain
    - 208Coins
    2DOF, SCN5
    This plugin has roll for sure
