Cytron md30c 30A Driver anyone tested?
Discussion in 'Motor actuators and drivers' started by DOFreality, Dec 2, 2018.
  1. DOFreality
    DOFreality Member
    Montreal
    344Coins
    Just found this wonder. 30A and no heat-think at 31$
    looks too goo to be true.
    What are these 10 small ICs?
    any thoughts / experience?
    https://www.cytron.io/p-md30c
    152,331Coins
    +11,072 / 56 / -2
  3. DOFreality
    DOFreality Member
    Montreal
    344Coins
    I saw it, but don't believe no one tested them yet since 2013....
  4. BlazinH
    16,667Coins
    Mosfets.
  5. Alexey
    Alexey Well-Known Member
    Electronics Technician
    Adelaide, Australia
    8,066Coins
    The only issue I can see visually is heat dissipation. Like most cheaper drivers you will need to add some yourself.
    Looks like there are heat pads that go to the underside of the PCB so thats is where you will most likely have to place the heatsink as the top of the board is quite busy.
    Apart from that the reviews seem good, though there aren' that many in total.
  6. superwhitewish
    superwhitewish Member
    Avionic Engineer
    Malaysia
    225Coins
    I'm from the country where this motor driver is coming from and I am using it in my motion simulator.
    I use 2 large wiper motor (>100w i think) that burn 2 motomonsters(China) with large heatsink & cooling fan previously. But with these drivers the temperature is so low that I ended up putting them inside a fully closed box with no ventilation holes at all.(Except holes for wires & usb connection). Have been almost 2 years without any problem. Maybe I can take pictures later.
  7. kerya5
    kerya5 and instead of the heart a fiery motor
    Voronezh
    Russia
    - 1,177Coins
    2DOF, Arduino, Motion platform, 4DOF
    hello, dear Superwhite!
    Do you have plans to create a 4DOF car simulator?
    I want to use Cytron mdds30 like You! I am currently working on 4DOF.
    May i ask some questions?
    thanks.
